Leaf springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baboltin, Aug 2, 2024.
  1. Aug 2, 2024 at 10:16 AM
    baboltin
    baboltin [OP] New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    I am having a dilemma on leaf springs originally I wanted the dobinson 111 leafs because it seemed like from the research I had done on here everyone liked them and they didn’t get squeaky like other brands, but they give you two inches of height and honestly I would really only like 1-1 1/2 inches of lift from them, so then I started looking at deavers and they have a plethora of choices.
    what do you recommend for a leaf spring that is between 1 and 1 1/2 inches of lift, and doesn’t get squeaky? Also weight wise I will have a camper shell always on the truck, HC rear bumper with a spare tire on it, and at some point will purchase a small travel trailer for the family and be towing it. With all of that weight what is the best leaf spring to accommodate the weight ?
    thanks everyone in advance.
    HondaGM likes this.
  2. Aug 2, 2024 at 10:50 AM
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
  3. Aug 2, 2024 at 10:52 AM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Everyone says they squeak because originally I planned on these because they fit my needs until I heard that everyone was complaining about them squeaking.
  4. Aug 2, 2024 at 10:59 AM
    Southwest Tacoma
    Southwest
    No squeaks on mine so far. 3 months in.
    AusBerg likes this.
  5. Aug 2, 2024 at 11:02 AM
    bigmw
    bigmw Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
    I have a very similar setup as you, and I went with Alcan springs. So far they are great, I think it's been 3 years now
    baboltin[OP], LOLLY and monoman like this.
  6. Aug 2, 2024 at 11:59 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Yup, I went with Alcan's too when I had my 1st Gen for a 2" lift, never had any squeaks with em...I also had greaseable rear shackles too...
    bigmw[QUOTED] and LOLLY like this.
  7. Aug 2, 2024 at 12:03 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I like my Icon RTXs, but they do squeak like a mutha. So far any spray, water, silicone, whale spuug,, or any other mystery lube only lasts about 14.5 miles. The good news is; my GF now refuses to drive my truck.
  8. Aug 2, 2024 at 3:20 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    I know 2 people that have icon rxt and they squeak. I have Deavers and work fine. I know some guys that run the Archive medium and are pretty happy with them. They do have quite a bit of lift so probably Deavers stage 1’s.
  9. Aug 2, 2024 at 3:21 PM
    Southwest Tacoma
    Southwest
    So, what causes the squeak? Living in a wet climate? Rust? Dirt?
  10. Aug 2, 2024 at 3:21 PM
    AusBerg
    AusBerg Well-Known Member
    Austin
    North MN
    2022 TRD OR DCLB
    Hmm I got icons stage 3, no squeak here, but I do wool wax so maybe that helps
  11. Aug 2, 2024 at 4:21 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Apparently them being too clean.
    My Icon RXTs started to make a slight bit of noise maybe a month after I put them on... until I went on my first offroading trip. They fully went silent after that (had the same thing also happen with Skyjacker leafs on a Ford Ranger).
    I think noisy leaf springs are simply telling you you don't go offroad enough and that you wasted your $$$ on expensive leaf springs :D )
  12. Aug 2, 2024 at 4:26 PM
    BillyE
    BillyE Well-Known Member
    I’ve had deavers on two trucks with no squeaks.
    baboltin[OP] likes this.
  13. Aug 2, 2024 at 6:32 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I have dobinsons 112's and they have been great compared to my ome's a bit of squeak here and there but nothing crazy. They hold weight like no other ill tell you that much. Easily 500lbs in tools and recovery gear in my box currently plus the cover rack and tent still sits high and pretty compared to my ome 111's that sagged at the sight of the tool box
  14. Aug 2, 2024 at 7:11 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    X3 for Alcan's. Plus they do whatever lift and weight capacity that meets your needs.
    monoman and bigmw like this.
  15. Aug 2, 2024 at 7:24 PM
    lupercal
    lupercal Well-Known Member
    Portland, OR
    2020 OR DCSB
    Archive Garage has some great leaf springs. (They have a vendor section on TW if you want to ask about em)
  16. Aug 2, 2024 at 8:01 PM
    SpeySquatch
    2016 TRD OR DCSB
    Mine don’t squeak ever, at all. And I live where it gets dusty. Just grease em before you put them on. And make sure they are torqued nice and tight.
    baboltin[QUOTED][OP] likes this.
  17. Aug 2, 2024 at 8:09 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    While I have the OEM 4 leaf pack, I’m running near 200K on them. At one point I thought they squeaked. I tried just about ever trick and lube available. I finally had a need to replace the rear shocks and now no more squeak. I’m pretty sure the worn shock bushing was the source of the squeak.
  18. Aug 2, 2024 at 8:35 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I’m getting some Alcans made soon. To my weight and lift height I want. Buddy has ran them on his Toyota pickup for 9 years and they are going strong still.
    monoman, LOLLY and bigmw like this.
  19. Aug 3, 2024 at 8:45 AM
    PiñonTaco
    PiñonTaco Well-Known Member
    2020 TRD OR DCLB
    71tattooguy, baboltin[OP] and Chew like this.
  20. Aug 5, 2024 at 12:00 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Sounds like the Alcans are the ticket, I imagine with them being custom your weight and height you want to obtain, they are pretty costly. I looked and they didn’t have any basic pricing on there site for just leaf springs but I guess I will either go with those or deavers since it’s a fan favorite and no complaints of squeaking.
