Leaf Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StarGazer, Mar 30, 2010.
  1. Mar 30, 2010 at 5:33 PM
    StarGazer
    StarGazer [OP] Well-Known Member
    MegaMan!
    Wherever, Tx.
    2007.5 Dodge Ram 2500 Mega Cab 4x4
    I've done so many mods to this truck it turned out to be a Dodge Ram 2500! WOW was that expensive!!
    I just recently noticed that my right side leaf springs creek or squeak every time I get in or out of my truck. Should I worry about them or is that just an age thing?
  2. Mar 30, 2010 at 5:34 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    No biggie. you can grease between the leafs though to help get rid of some of the noise.
  3. Mar 30, 2010 at 6:09 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars w/Thules ski and bike attachments, JVC MP3 Head Unit, TRD Cat Back Exhaust, roadmaster active rear suspension, more when $$$ allows
    I'll try and find you the part number. I just ordered the parts for the rear spring sqeak TSB that was updated August 2009. There's a new set of spring pads that go between each of the leafs. These are already included on the newer Tacoma's that started being produced I think with the 2008 model year. The pads are self lubricating and eliminate the squeak. Grease and stuff was the origional fix however it only lasts for a while and the practice was discontinued by Toyota.
    The part is $22 for a three leaf setup. If you have 4 leaf's then you have to get two of the same part number.
  4. Mar 30, 2010 at 6:15 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I don't think the 2008's were included or at least the tsb springs they put on mine because mine squeak like there's no tomorrow if I don't keep them greased up well.
  5. Mar 30, 2010 at 6:41 PM
    StarGazer
    MegaMan!
    Wherever, Tx.
    What kind of grease and where do I apply it?
  6. Mar 30, 2010 at 6:43 PM
    Jason'sLawnCare
    The stuff you can get in a tube from home depot or the like.
    Jack up the truck(To give your self more room) then use a long screw driver or pry bar to spread the leafs apart. Remove the silencer pads(at the end of each leaf) 4 per a side iirc. clean them off and clean where you removed the pads from. Lube the pads up really well with grease from a stick what would go in a grease gun. I also lube where I put the pads back using popsicle sticks just to be certain I had everything covered. Then put the silencer pads back in the whole and make sure the seat properly. If not then you'll notice a gap between the leafs. Remove the screwdriver or pry bar. Repeat for all 8 and you should be squeak free.
  7. Mar 30, 2010 at 7:33 PM
    j4x4ar3
    Jay
    Austin, TX
    The TSB is dated August 13th, 2009 and is for ALL 2005-2009 Tacoma's and was updated to include the 2008-2009 models that were not contained in TSB T-SU012-07.
    The new TSB is T-SB-0274-09
    The part number is 04009-09104 and was $22.01 from my dealer.
    These are different pads than were in the previous TSB as well and do not require the grease as is stated by the previous poster. The TSB specifically states tht technicians should discontinue the use of any type of grease between the silencer pad and spring as the new pad is a self lubricating surface (probably some sort of synthetic pad).
  8. Mar 31, 2010 at 11:33 AM
    Jason'sLawnCare
    Thanks for the info. I guess they put the old silencer pads in my leaf springs when they swapped them out for the 4 leaf pack.
  9. Mar 31, 2010 at 5:52 PM
    StarGazer
    MegaMan!
    Wherever, Tx.
    Ditto on the info too. Thanks!
  10. Mar 31, 2010 at 6:00 PM
    rjreynolds
    rjreynolds Active Member
    2wd 2.7l
    I have an 08 and my leaf springs squeak as well. It is not really a big deal to me so it's not on the top of my list of things to do. however, I will do the fix at some point.
  11. Apr 1, 2010 at 5:33 PM
    j4x4ar3
    Jay
    Austin, TX
    Just picked up the parts. They're actually just synthetic disks that replace the existing pads. I'll try and take some photos and post this weekend. Maybe I can do a good enough write up to get a sticky.
  12. May 26, 2010 at 12:11 PM
    Tugboatdude
    Tugboatdude Team Wonderbread
    Jim
    So Cal
    08 4X4 TRD Sport Long Bed
    6in Pro Comp, 17x8.5" Razor Rims, 35in BFG's, Tinted windows, Piaa lights. Magna Flow cat back exhaust.
    How did you put them in? Did you unbolt the leaf springs or just pry them apart with a big ass screw driver??
  13. May 26, 2010 at 12:51 PM
    chanes8cwu
    chanes8cwu Well-Known Member
    Joe
    Black Diamond, WA
    2012 DCLB Tacoma 4.0L
    What dealer did you get this from? Mine said they dont carry them and would most likely be aftermarket parts....
  14. May 26, 2010 at 1:40 PM
    Jason'sLawnCare
    I can pull out my squeeky pads with a big ass screw driver. That's how I grease them up. So if they are about the same size you can just pry the leafs apart. You don't even need to remove the wheel.
  15. May 26, 2010 at 10:28 PM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    u don't need to pull the leafs apart. just jack the truck up and there should be enough space between them to get a thin putty knife thing (i think thats what it was) and just spread the grease around like butter. if you want to go all out, u can pull them all apart and spray rustproofing.
  16. May 27, 2010 at 3:17 AM
    Tugboatdude
    Jim
    So Cal
    Sweet thanks for the info...
