Leaf Suggestions!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dnaTRD, May 16, 2018.
  1. May 16, 2018 at 3:18 PM
    dnaTRD
    dnaTRD [OP] Well-Known Member
    What is the difference between AAL and 3 leaf AAL? What's the advantage or disadvantage between the two? I am considering lifting my truck and don't know which one to choose.
    Considering 5100's, 887 coil, 1/4" spacer, and (either AAL or 3 leaf AAL)...Looking to get as close to 3" of lift.
    Thanks guys!!
    oh and here she is.....
  2. May 16, 2018 at 3:21 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    AAL adds a single leaf to your stock pack
    3 AAL adds a small pack of 3 leaves.
    The only experience I have with AAL is when I ran 5100s and a single Deaver AAL in the rear. Brought me level at about 3" on my old prerunner. If you still want a bit of rake (looks) or load carrying capacity (function), get the 3 AAL. FWIW, the 3 AAL without weight in the bed will ride a bit stiff.
    dnaTRD [OP] likes this.
  3. May 16, 2018 at 3:23 PM
    GHOST SHIP
    GHOST
    Please remove the word "help!" from your thread title. How about "Leaf suggestions" or "AAL questions"?
  4. May 16, 2018 at 3:23 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    2005 black sand pearl TRD OR
    stickers and sticker accessory's
    I run the icon 3 leaf and took my overload spring out. I find it rides way nicer than stock its not super stiff, gave me like 1.5-2 inches
  5. May 16, 2018 at 3:25 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    My experience was opposite. The single AAL was much stiffer and rode pretty bad empty but carried heavy loads better. The 3 leaf with the overload left in rode far smoother, flexed better off-road but wouldn’t support a heavy load as well.
    GHOST SHIP likes this.
  6. May 16, 2018 at 3:28 PM
    GHOST SHIP
    GHOST
    Like I mentioned, I had only experienced the single leaf. I surmised from other posts that the 3 AAL would be stiffer since people mentioned it helped with weight. Thanks for correcting me.
  7. May 16, 2018 at 3:28 PM
    dnaTRD
    Did you guys replace your stock bump stops when lifting? If anything, I would be hauling more weight than off roading.
  8. May 16, 2018 at 3:30 PM
    dnaTRD
    I am leaning towards the single AAL. I'd prefer the truck to look/ride level with the lift I am considering.
  9. May 16, 2018 at 5:44 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Lynnwood wa.
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Any leaf configuration for achieving 6" of lift? Or are blocks to only way?
