LEAF SWAP / 5 TO 6 LUG / PICS
Discussion in 'Street Trucks' started by Beefed Taco, Nov 26, 2012.
  1. Nov 26, 2012 at 5:51 PM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    SPECIMEN
    04 Taco dropped 5/6 with leaf pulled from 5-lug packs. (leaf drop and 3-1/4" custom Streetacos blocks that have pin & hole located correctly to pull the axle back where it should be when using leaf drop) Pics of truck in this first post are before pics. It sits the same with the 6 lug leafs and leaf pulled and is using the same 3-1/4" Streetacos steel blocks.
    6 LUG LEAF INFO:
    6 lug leafs are side specific. It's nice to get a set that still has the factory part #'s painted on them.
    RIGHT SIDE / Part # ending in 210 and numbers are painted white.
    LEFT SIDE / Part # ending in 220 and numbers are painted yellow.
    IMPORTANT SHACKLE INFORMATION
    95.5-00 5 LUG TRUCKS
    The shackles on these trucks have a fat 18mm lower stud that runs through 2 leaf spring bushings that are easily removed by hand from the leaf spring. All 6 lug leaf springs, no matter the year, have pressed in bushings that use smaller 14mm (9/16") diameter stud. This means if you're swapping 6 lug leafs onto a 95.5-00 5 lug truck, you'll need to pop out the lower 18mm stud from the outer shackle piece (the wall) and replace this 18mm stud with a smaller 9/16" x 4" grade 8 bolt. The outer shackle piece of each shackle, (the wall) will have a 18mm hole on bottom with a new 9/16" bolt running through it. Sloppy. I weld a 9/16" washer to the bottom of the shackle piece (the wall) so the bolt running through the leaf spring fits the outer shackle wall nice and tight with no slop.
    01-04 5 LUG TRUCKS
    Have smaller 14mm (9/16") bolts on bottom of the shackle, unlike the fatter 18mm ones on 95.5-00 5 lug trucks. The bushing in the leaf spring is pressed in, and uses a 14mm shackle stud. No shackle mods are necessary to swap 6 lug leafs onto 01-04 5 lug trucks, as in the case with this 2004 in this thread.
    I encourage folks to leave any comments regarding your project or any tips and info you may have. waytogo_efd99798f0894b5d8f66f654e06bf149f4481ac3.gif
  2. Nov 26, 2012 at 5:52 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    PICS
    1)
    With truck on jack stands, undo bottom of shocks (not the top) and let them hang with axle fully dropped out. Remove u-bolts and shock plates.
    2)
    Use 2 more jack stands to raise axle up onto so you can remove the leaf springs.
    3)
    The difference of a stock 5 lug pack (top) vs a 6 lug pack (bottom)
    4)
    Here I'm getting ready to remove the leaf below the top leaf in the 6 lug packs. Use pliers to pop out the plastic pad so the leaf slides out easier.
    5)
    I chose to clamp the leaf I'm removing in a vise and pound the main leaf downward and eventually out.
  3. Nov 26, 2012 at 5:52 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    PICS
    1 (6)
    Swap the 5 lug over load leaf onto the 6 lug packs that will be installed. They aren't as curved and pointy on the ends and will clear speed bumps easier. NOTE: Don't forget to smear some grease between the leafs so they slide easily on one another and don't squeak. I like to use anti seize on the shackles and the front leaf bolt to keep corrosion away and allow easy dis assembly later on.
    2 (7)
    Make sure when you install the little bolt that holds the leaf pack together that it tightens down all the way. If you run out of threads and the nut doesn't tighten fully, use a small diameter washer behind the nut. These 6 lug bolts tightened down nice even with the leaf I chose to remove missing.
    3 (8)
    Install leaf spring. NOTE: Don't tighten the shackle nuts and the front leaf bolt all the way yet. Pictured is the leaf spring that you remove from 6 lug packs when looking for a 3" leaf drop.
    4 (9)
    This is why you want to use anti seize or grease on the shackles and leaf bolts...the right shackle was a nice shiny gold but this left shackle had corrosion forming. And this is on a very clean truck from California.
    5 (10)
    Both sides are completely finished here and the truck has been raised off the jack stands with a floor jack under the axle. With the truck raised up, simulating ride height, you can now tighten the front leaf bolts and the shackles fully. The reason for waiting to do this is because this is where the leaf bushings will ride when the truck is on the ground, so by tightening the hardware up in this position will ensure the bushings are how they should be when tightened and will eliminate stress placed on them as if you had tightened the hardware up with the suspension dropped out. waytogo_efd99798f0894b5d8f66f654e06bf149f4481ac3.gif
  4. Nov 28, 2012 at 8:14 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Here are a couple after pics. 2002 6 lug leafs with 3-1/4" blocks. Something I should mention is... In the before and after pics in this thread, there are a set of leaf springs in the bed. In the after pics, his old 5 lug leafs are in the bed, which probably doesn't make it squat very much, but it's worth mentioning.
    When I originally lowered this truck, I talked him out of using 4" blocks but decided to do 3-1/4" rather than normal 3" ones since I knew he wanted to be low, but still retain a nice daily ride without the extra cross member mods, and having to chop his new Belltech coils to match the rear. I kept the drop simple and more affordable, since he was already buying new BT coils, 4 KYB shocks, and paying for a c-notch and also the drop labor.
    I'm very impressed with this truck. He keeps it sooo clean, being garaged helps. The simple combination of drop parts, KYB shocks, c-notch, and tire size make this truck one heck of a nice truck to drive everyday. It's been 2 years since I lowered it and it hasn't changed one bit since then.
  5. Dec 6, 2012 at 10:03 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    haha, thanks for posting. I hear ya...it's got to be lowered or lifted, anything in between is just toooo common!
