Leaf TSB completed on 2011..PICS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nrm, Jan 15, 2011.
  1. Jan 15, 2011 at 11:21 AM
    nrm
    nrm [OP] Well-Known Member
    NC
    2011 4.0 DCSB TRD Off-Road
    4-leaf TSB and Eibach 620 coils with Bilstein 5100's set to 0". AFE intake and Gibson cat-back exhaust. Bestop canvas topper
    Does anyone else have a pre-TSB measurement on a TRD off-road? I know it can differ from vehicle to vehicle but I'm just curious how much mine changed since I forgot to get a "pre" measurement.
    Before
    After
    Couple things:
    1) It appears the serial number on the leafs have been "altered". You can clearly tell that one of the numbers on both the LH and RH have been changed. Has anyone else noticed this? I mean it's definitely stiffer and lifted some but doesn't appear as lifted as a lot of other members' who have posted pics post TSB...
    2) I forgot to get a measurement beforehand but I'm now at about 37.5" ground to top of wheel-well through the center cap.
    I've got 5100's on the way and I would have waited until I put them on to take in for the TSB to get the free alignment but I got a pair last minute a few days ago after I had already scheduled the TSB. And actually, I really don't mind the rake it's at right now. Think I'm just gonna set the 5100's to .85 when I put them on.
  2. Jan 15, 2011 at 6:14 PM
    N.GA Taco x3
    N.GA Taco x3 Well-Known Member
    Kevin
    Georgia
    11 Pre DC Sport- 02 Pre DC OR- 12 DCSB 4x4
    I have measured my non-TSB 2011 Pre, but it is a sport, not OR, rear drivers side is 36.75"
  3. Jan 15, 2011 at 8:26 PM
    nrm
    NC
    Thanks,
    Yeah just judging by the visuals, I'm pretty sure I got about 1.5" out of the TSB but it hasn't had time to settle yet.
  4. Jan 15, 2011 at 8:34 PM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    Mine is going in on tuesday for leaf spring TSB. I tried to convince the serv manager to do the steering coloum tsb since the wheel shakes but he said we'll do I at another time. He'll see when i rip him around the block the wiggle it has. I'll take both measurments the day i drop it off. Oh yeah it took 4 calls to finally get them to do tbs, they were most convinced when i drove up there with snow packed in back and it was nose WAY high
  5. Jan 15, 2011 at 8:37 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The TSB springs will settle to approx 3/4 " over your stock US 3 leaf pack , the time they take to settle will depend on the amount of weight you haul in the bed.
  6. Jan 17, 2011 at 11:27 AM
    nrm
    NC
    The first day I went in and requested the TSB, he said they'd have to check out my truck and took it into the back for 30min. Not sure if they load tested it or just checked out the VIN and made sure it fell under the TSB but he came right back out and said he'd order the parts. The day I took it in to have it done, I was confronted by another service associate who grilled me on why I needed it done because he had a Taco and never had an issue towing, yada yada...
    Thanks! Good to know
  7. Jan 17, 2011 at 6:00 PM
    GeoTaco1
    GeoTaco1 Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    I assume it will make it a bit firmer in the back, but when the bed is empty, can it result in some rear wheel instability? Could someone explain the wheel shake TSB?
  8. Jan 17, 2011 at 6:02 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    looks good
  9. Jan 17, 2011 at 9:59 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    No need to clutter the board with a one thousand and one more tsb posts, so other than the 4th leaf, what does the new spring do? Does it only soften up the ride if you are carrying something in the bed? Thanks.
  10. Jan 17, 2011 at 10:10 PM
    nrm
    NC
    I haven't noticed any such instability in the rear. Definitely stiffer, but I like it. As many others have said, it feels more like a truck should. The wheel shake mentioned has to do with the steering column, this thread's stickied at the top of the 2nd gen forum...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/99531-steering-wheel-shake.html
    The extra spring allows for more towing capacity without bottoming out your rear suspension. And although I haven't had it loaded down yet since getting the tsb done, I would imagine the ride would soften up with it loaded down some.
  11. Jan 17, 2011 at 11:57 PM
    Wile
    Wile It's a truck not a luxury sedan.
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    I hadn't notice much change in my DC TRD OR when I had the TSB done. You noticed a big difference? Maybe I didn't because it's an 2008. I dunno. :)
