leaf under axle to leaf above axle... help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by br217398, Feb 5, 2009.
  1. Feb 5, 2009 at 3:42 PM
    br217398
    br217398 [OP] Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    im thinking about moving the spring above axle on my 5lug.... except for the bump stop... im noting seeing much differance.. is there???
  2. Feb 5, 2009 at 3:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You'll get about 5" of lift (height of the axle tube approx).
    And with 5" of lift, you'll have all sorts of other things to change.
  3. Feb 5, 2009 at 4:04 PM
    br217398
    Orlando Florida
    so in other words, unless i REEEALY want to be fixing my truck till 2015 i should leave it where its at?? :)
  4. Feb 5, 2009 at 4:13 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    lol.... :thumbsup:
    me thinks so...
  5. Feb 5, 2009 at 7:04 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    theyre's a thread over at custom tacos on this...it supposedly would only yield about 3" of lift...
    which still would be alot for our 5 lugs....
  6. Feb 5, 2009 at 7:23 PM
    br217398
    Orlando Florida
    ^^^hmm ive got to find that
  7. Feb 5, 2009 at 9:11 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    http://www.customtacos.com/forum/showthread.php?t=120337&page=2
    honestly, i dont see why this would be THAT hard to pull off
    you could always just get the pre-runner hardware, like the whole shock mount axle thing (i dont know what the hell its called, but the part that is on the botom of the axle supporting it with the shock mount and all) and the U-bolts meant for leaf over axle....theyre completley different, 5 lugs have the more U shaped ones that are parallel to the leafs while the 6 lugs have U bolts that have the U perpendicalar to the leafs with a U shape that is conformed to the leafs and not the axle
  8. Feb 5, 2009 at 10:30 PM
    Janster
    Jandy
    Lancaster, PA
    Not that you'd be fixing your truck - but you would have A LOT of work to do to get it where it is now (controllability, drivability, etc).
    Flipping the leaf springs to the top sounds easy enough - some spring perches, welding...sounds easy.
    But people tend to forget about the OTHER stuff that's involved - and I can only really comment on the rear (driveline issues, shock length, brake lines, etc). The front? Well.....steering, allignment, etc.
  9. Feb 6, 2009 at 7:57 AM
    br217398
    Orlando Florida
    forgot about longer brake lines......and id definatly need a diff drop front and rear axledrop to save the ujoints..
  10. Feb 6, 2009 at 9:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If your truck is a 2 wheel drive, no diff or axels in the front to drop.
  11. Feb 6, 2009 at 10:21 AM
    br217398
    Orlando Florida
    yep im cluless now.......
  12. Feb 6, 2009 at 10:36 AM
    Delmarva
    Tucson, AZ
    x2... seems like it should be more... :D
  13. Feb 6, 2009 at 6:56 PM
    br217398
    Orlando Florida
    im about good as fabricating brackets and crap, as cutting a dang
    PB and J sandwich ill leave that to the professionals but atleast it souds easy
