leafs are not straight in leaf pack
Discussion in '1st Gen. Tacomas (1995-2004)' started by mackattack07, Oct 16, 2011.
  1. Oct 16, 2011 at 3:56 PM
    mackattack07
    mackattack07 [OP] Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    Is this bad or ok? The leafs do not line up strait in the pack The bands are still secure. and the truck was on level ground when these pictures were taken.
  2. Oct 16, 2011 at 5:23 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
  3. Oct 16, 2011 at 5:28 PM
    mackattack07
    william
    It seems like they should be straight but if its normal thats good. I may still tell the wife i need new ones and ditch the blocks for some better ones. Thanks guys
  4. Oct 16, 2011 at 5:29 PM
    NegroTundra
    Land of Enchantment
    Yeah definitely use whatever excuse you can to ditch blocks and get a real rear lift setup
  5. Oct 16, 2011 at 5:30 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    They are usually lined up, but it won't hurt anything the way they are.
  6. Oct 16, 2011 at 6:15 PM
    mackattack07
    william
    got a weird rear vibe thaught it may be connected cause ive looked into everything i can think of thats not real invasive
  7. Oct 16, 2011 at 6:18 PM
    S.B.
    Sean
    During just braking and acceleration or all the time when moving?
    If at stop and gos then its axles wrap and the block lift makes it worse.
    If all the time when moving then its your carrier bearing (if you have a 2 piece Drive Shaft), not much you can do unless the bearing is bad.
  8. Oct 16, 2011 at 6:34 PM
    mackattack07
    william
    its all the time when moving i moved the drive shaft around in the mount how much play should it have. and i did notice when i put my truck in gear now i have a ping noise esspecially when on hills.
  9. Oct 16, 2011 at 6:47 PM
    erisman33
    erisman33 Crawlin Over 1 Rock At A Time
    Pismo/Mendocino
    1995 Ton'd Taco
    1 Tons with 4 Wheel Disc
    Try flexing or getting the weight of one tire and take a BIG Hammer and hit them to straight them out if you really care. Easy fix and takes about 5 minutes or so.
  10. Oct 16, 2011 at 6:49 PM
    erisman33
    Pismo/Mendocino
    1995 Ton'd Taco
    Sounds like a center support in the middle of your driveline. Possible u joint but i would lean more towards center support
  11. Nov 3, 2011 at 8:50 PM
    1998tacomaowner
    1998tacomaowner Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    man i wish i had a pic of my stock leafs they started out like that but buy the time i had enough $ to fix them i had one leaf left stock leafs are shit
  12. Nov 4, 2011 at 7:53 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Got some 3" lift ones I'm selling. They were on it when I bought my '99 and still have that lift bc I don't really carry anymore weight than just a toolbox in the back. I'm selling cheap for a fast sale, so feel free to PM.
    I don't know what brand they are, but can tell you they ride pretty good. I took them off my truck and cleaned them up and spray painted them black to stop what ever rusting they had and to give them a cleaner appearance. They have six leafs and the overload if that helps.
    $150.00 for them both and I can pay shipping with my LTL account.
  13. Nov 4, 2011 at 5:18 PM
    96taco4x4
    96taco4x4 Active Member
    Austen
    Florida
    96 SAS Taco
    center support bearing? like a carrier? i have a 2 piece also and no for sure i dont have a support bearing? did that come stock on all 2 piece rear shafts?? could be where im getting my vibe
  14. Nov 6, 2011 at 8:57 AM
    marcchrisv
    marcchrisv Well-Known Member
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Toytec 2.5" lift., just the beginning. Front Builstein coil-overs fully adjustable from 0-3". 2" AAL in the rear with 2.5 degree shim. Total Chaos uni-ball UCA's.
    I agree, go with full set of springs, or if you want to go cheaper you could always do an AAL. Blocks are Bad.. They are the primary cause of excessive axle wrap.
  15. Nov 6, 2011 at 9:13 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you have a two piece shaft you do indeed have a center support/carrier bearing.
