Leafs or shocks first... rear end?
Discussion in '1st Gen. Tacomas (1995-2004)' started by xguntherc, May 24, 2019.
  1. May 24, 2019 at 9:54 AM
    xguntherc
    xguntherc [OP] Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    The lady has an older 2002 Taco with about 150k miles.. Still runs and drives great, but obviously the back end is a little worn out, rough, and goes over speedbumps pretty brutally.
    To improve the ride a bit and soften things up should she replace the leafs first (or an AAL) or replace the shocks first?
    Thanks!
  2. May 24, 2019 at 9:57 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    This is just an anecdote, and not an answer... I tried to get new shocks and deaver j59s...
    I didn't get shocks that would work with the j59s, some are being made, I hope to get
    them soon. I'm running now with the new leafs and slap-wore-out who-knows-what
    kind of shocks, it is ... OK ... :) ...
    -Mike
    xguntherc[OP] likes this.
  3. May 24, 2019 at 10:05 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Do both at the same time. Seriously, they are right down there in the same area and they compliment each other as the suspension works.
  4. May 24, 2019 at 10:15 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It really depends. If you plan to just keep it at stock height, I would go ahead with the shocks first. Given the age of these trucks, it's not hard to assume that the springs are also worn out. But the shocks will give you the most noticeable improvement in ride.
    Very common shocks are the Bilstien 4600s (for stock height). However, if this person wants a softer ride, she may consider Monroes, as I hear (no personal experience with them) they provide a "softer" ride than billies. Keep in mind, it's a pickup truck, so a "soft ride" is relative.
    If she is considering lifting the truck, I would decide on the springs first, THEN get the shocks to match at the same time.
    But whatever you do, don't get an add-a-leaf if the goal is a softer ride.
    Wulf and xguntherc[OP] like this.
  5. May 24, 2019 at 10:39 AM
    xguntherc
    Cory
    East Dallas
    Thanks for the input guys. Nah I don't think she wants a lift, and she's working on a budget.
    4600's are the stock shocks right? Are there 5100's that fit or no? and I actually saw some "like-new" Monroes on CL locally. idk.
  6. May 24, 2019 at 11:06 AM
    jbrandt
    Justin
    No, they aren't the stock shocks, even though the TRDs come with billstiens, they aren't 4600s.
    If you look at a set of oem take-offs from a TRD, vs. the 4600s, they are larger diameter than the oem billsteins. There's an older thread around here somewhere that shows the difference...
    The 4600s and 5100s are very close to being the same. They're essentially valved the same, afaik. The main difference is the front 5100s are height adjustable, and the rear 5100s are slightly longer and require at least 1" lift to fit. The front 5100s can be run at stock height.
  7. May 24, 2019 at 11:10 AM
    tony2018
    tony2018 Well-Known Member
    Shocks are easy but I'm guessing your leaf springs are probably out too.
  8. May 24, 2019 at 11:19 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Usually these trucks ride softer as they age, not harder. I think what you need is just some new, firm suspension components that will give you more control over bumps, turns, potholes etc. Id grab a set of the Bilstein 4600's.
  9. May 24, 2019 at 11:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    No lifting coming up, do the shocks first. Easy peasy and the OE shocks were done 100k ago anyway.
    If you still have issues (or find that the springs are in poor condition while under there poking around), then deal with that.
  10. May 24, 2019 at 7:29 PM
    xguntherc
    Cory
    East Dallas
    Thx guys
