Leak around oil drain screw...thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dee_bo, Nov 14, 2009.
  1. Nov 14, 2009 at 12:45 PM
    dee_bo
    dee_bo [OP] Well-Known Member
    DFW
    2007 TRD Sport Tacoma
    None yet
    I just bought a used 2007 Tacoma and while inspecting it before purchase I noticed a leak around the washer of the oil drain bolt. I got the private owner to decrease it by $100 and he signed that if the pan thread is f;d and needs replacing he is responsible for the costs. I just got a new oil plug with washer and hope that fixes it....any suggestions?
  2. Nov 14, 2009 at 1:01 PM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    The washer is bad- put in the new one and it'll be fine.
  3. Nov 14, 2009 at 1:32 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The seller paid $100 for a $.20 item. Nice.
  4. Nov 14, 2009 at 1:57 PM
    dee_bo
    DFW
    None yet
    Yeah I changes the washer but kept the bolt the same. The old metal washer has some corrosion looks like. I'm hoping that solves it. Spent $2.99 for a bolt and washer....so hopefully I saved $97 with the trade off lol
  5. Nov 14, 2009 at 2:02 PM
    dee_bo
    DFW
    None yet
    Well the washer i got now is plastic...so i'll change that every so often....guess every 3 oil changes sounds right
  6. Nov 14, 2009 at 4:50 PM
    JKD
    JKD Well-Known Member
    I am constantly baffled as to how my 1998 Plymouth has its factory original oil pan bolt and integral seal, with zero leaks, but a 2009 Tacoma "needs" a new seal ever oil change or so.
    Come to think of it, I'm pretty sure my '64 Plymouth oil pan bolt has its original seal too.
  7. Nov 14, 2009 at 4:55 PM
    dee_bo
    DFW
    None yet
    I also have a 1998 frontier and I have never had to replace the bolt/washer. Guess they don't make things like they use to lol
  8. Nov 14, 2009 at 4:55 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 4Runner TRDOR Prem. MGM
    fwiw, I have never changed the crush washer on either of my vehicles. no problems thus far
  9. Nov 14, 2009 at 4:58 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Yeah it sounds like the washer is bad, just like others have mentioned above.
    Just make sure not to tighten it too much using the new washer, you can use a torque wrench. 15-20 ft. pounds outta be good.
  10. Nov 14, 2009 at 5:10 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You don't even need that much, just hand tight is fine. The vacuum created by the engine will tighten it further...
    Also, +1 for the crush washer leaking. I haven't changed mine yet at 30k... no issues. I've never changed them... but hey easy fix and a great way to save some bones.
  11. Nov 14, 2009 at 5:17 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    What? Never heard of a vacuum by the engine tightening a screw before? What the hell are you talking about?
    The reason why I suggested that he use a torque wrench is because people over tighten the bolt and crush the washer too much, and cause it to be harder to take off the bolt.
  12. Nov 14, 2009 at 5:33 PM
    JKD
    I've heard this several times on this board...questioned it...never answered.
    There is no significant vacuum in the oil pan, aside from the tiny vacuum created by crankcase ventilation. And even if there was, it can't tighten a bolt.
    :confused:
  13. Nov 14, 2009 at 5:37 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    lol...yeah. The oil pump will pick up oil but won't tighten up a bolt.
    It seems like every tip I give to people, someone always has to have a remark on it. I can understand if I'm wrong on something, but damn.
  14. Nov 14, 2009 at 9:42 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I've got 245,000 miles on my echo with the same washer and no leaks. That's around 35 to 40 oil changes.
    Marc M
  15. Nov 15, 2009 at 12:10 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    They actually give you a new washer with every OEM filter.
    I don't know if he was just hooking me up or what but I paid $1.00 for 5 washers last year (I don't use OEM filters).
  16. Nov 15, 2009 at 9:33 AM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    Well dee_bo, did the new washer stop the leak?
  17. Apr 28, 2010 at 5:41 PM
    geyemd
    geyemd Member
    Mark
    Maricopa, AZ
    06 Tacoma PreRunner DCB Sport Speedway Blue
    OK, plastic washers are fine - you should change them every two oil changes, flipping the plastic washer over on the 2nd use of it. The suggested torque for oil pan #2 bolt is 30 ft/lbs.
    If your oil pan #2 threads are fucked, then you need a new oil pan #2 (oil pan #1 is at the bottom of your engine, this is not what we're talking about though).
    As Kyouto42 mentions above as a vacuum, it's not, it's oil pressure. The oil pressure force want's to push the bolt out, but obviously that wouldn't happen with a 20-30 ft/lbs torqued bolt.
    Take care.
  18. Apr 30, 2010 at 1:19 PM
    bigef12
    bigef12 Well-Known Member
    Eric
    Chattanooga, TN
    2004 4Runner SR5 4x4 V6
    Removed that stupid "Sport Bumper Trim"
    There are two oil pans?
  19. Apr 30, 2010 at 1:31 PM
    dee_bo
    DFW
    None yet
    Haha thanks man but you bumped my old post. I used a new plastic washer and no more oil leak...will need to replace it next oil change I think.
    The bolt was pretty loose when I changed it a week ago...think a metal washer is probably the way to go
  20. Apr 30, 2010 at 4:49 PM
    geyemd
    geyemd Member
    Mark
    Maricopa, AZ
    Why of course there is.
    http://www.customtacos.com/tech/fil...6toyrm/06toypdf/06rmsrc/rm2006ta/01800310.pdf
    Page LU-13
    Oil pan #1 (or officially called the 'OIL PAN SUB-ASSEMBLY') is directly below your engine, it's connected to the engine block and timing cover.
    Oil pan #2 (or officially called 'NO. 2 OIL PAN SUB-ASSEMBLY') is connected to the aforementioned oil pan #1. This is what everyone uses to change drain their oil.
    No problem dee_bo - crush washers work well, but like the name, over time they get crushed too much, ha. Replace one/twice a year.
    Take care.
