Leak at cab bed rail
Discussion in '3rd Gen. Tacomas (2016-2023)' started by finethreads, Jun 23, 2020.
  1. Jun 30, 2020 at 4:40 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I’m looking into buying a Tonneau cover. Doing some reading here I expect to need to do additional sealing. A friend bought a Gator Tailback a few weeks back and no leaks in a heavy rainstorm on a long drive but he has a Silverado. A fellow here has one on his Taco and likes it as well so I’m leaning toward that one. A tiny leak won’t bother me.
  2. Jun 30, 2020 at 4:49 PM
    lag7
    lag7 Well-Known Member
    Central Arkansas
    2019 Tacoma TRD Pro Super White
    Honestly Diamondback covers are great and I have tried to defeat the locks on mine haven't yet. Yes expensive but quality is super. Not their fault that the rail is higher than the bed caps. I don't expect perfections in any cover but tons better than the one I had on my other truck.
    davidstacoma[QUOTED] likes this.
  3. Jun 30, 2020 at 4:55 PM
    finethreads
    finethreads [OP] Active Member
    2018 TRD Off Road
    Well, I took the cab bed rail off (T30). I cleaned it up and ran a bead of clear RTV alongside the 1/2" felt "gasket" mentioned in a previous post.
    I reinstalled the bed rail and then pulled a hunk of HVAC sealant. I rolled it between my hands until it was the size of a big straw and then wrapped it all the way around the bed rail gap on both sides. I shaped it so that it feathered nicely into the side rails.
    I then coated it with the same RTV so it will not stick to the Diamondback cover gasket. I think this is going to do the trick. Will report back
    davidstacoma and Onwarrds like this.
  4. Jul 1, 2020 at 12:49 PM
    lag7
    Central Arkansas
    Yeah let me know. I may try to tackle this issue this holiday weekend since I am not traveling anywhere.
  5. Jul 4, 2020 at 11:19 AM
    lag7
    Central Arkansas
    Curious to know if that bead of RTC worked. I plugged my gaps with butyl rope this morning. This stopped the leak I saw before, however, I now have a leak (maybe from the same place the OP had) I didn't have before that causes water to pool on top of the front wheel wells. I assume I might have had the leak here before too but assumed it was from the gaps. Did the RTV solve your issue?
