Leak between transmission and tcase
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Levy49, Oct 27, 2023.
  1. Oct 27, 2023 at 1:21 PM
    Levy49
    Levy49 [OP] Well-Known Member
    2014 gun metal Tacoma trd
    Too many to list
    Anyone else have a problematic leak between their 6 speed trans and tcase, replaced the o ring that sits on the nose of tcase made it 100km and was leaking, drilled a small hole to fit a bore scope to make sure it's the same leak and sure enough it was, replaced it again this time filling the space behind the o ring with gear oil rtv, on a road trip and it's puking again, see pics for reference
  2. Oct 27, 2023 at 1:25 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You replaced the Oring and the seal?
  3. Oct 27, 2023 at 1:30 PM
    Levy49
    Too many to list
    Just the o ring, the seal on the tcase gets shoved into the trans so it wouldn't make an external leak
  4. Oct 27, 2023 at 1:34 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    @gearcruncher will probably know...may take him a minute to answer
  5. Oct 27, 2023 at 1:44 PM
    Levy49
    Too many to list
    One thing I thought of is the vent plugged or the original owner mixed the vent hose with a vacuum hose and the trans is getting pressurized (should mention it's supercharged, 10 psi at redline)
  6. Oct 27, 2023 at 5:08 PM
    gearcruncher
    Canadain bumper technician
    Your second picture doesnt look proper where the seal is suppose to fit into the casing .
    Looks like you had end play issues and the casing was eaten away where the seal bottoms out .
    I am sure there are other pictures hanging around at Tacoma World . Certainly shouldnt look that eaten up .
    Are you loosing transmission fluid or transfer case fluid ?
    Looks to be transmission fluid
  7. Oct 27, 2023 at 5:24 PM
    Levy49
    Too many to list
    Seem to be having a hard time finding a picture to compare, if you know of one could you post a link to it please, I'll let it cool down and pull the fill plugs see what one is low, I literally just did a driveline service so everything should be full but I agree it does appear to be coming from the trans
  8. Oct 27, 2023 at 5:30 PM
    gearcruncher
  9. Oct 27, 2023 at 5:34 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    the cruncher comes through again!
    HondaGM likes this.
  10. Oct 27, 2023 at 5:34 PM
    Levy49
    Too many to list
    I was on that form for about 10 min and just came across this pic, on mine it seems like it almost has a machined groove where the o ring sits but this one is flat if you understand what I'm saying. I'll give the dealer a call tomorrow and see if they can locate such a thing. Greatly appreciate the help I'll let you know what happens
    HondaGM likes this.
  11. Oct 27, 2023 at 5:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You sure that's the right o-ring? It looks like it's too big, it's not in the groove like it should be.
    HondaGM likes this.
  12. Oct 27, 2023 at 5:37 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Hopefully that's not a part of the case that's worn down. If it is then hopefully someone makes a redi-sleeve. If no one does then you may be able to get a CAT o-ring that's a bit thicker that'll seal everything up
    HondaGM likes this.
  13. Oct 27, 2023 at 5:38 PM
    Levy49
    Too many to list
    That was the old one before I replaced it, the new one sits snug, but good eye!
    HondaGM and Dm93[QUOTED] like this.
  14. Oct 27, 2023 at 5:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ah ok I was looking at that first picture going that can't be right.
    HondaGM likes this.
  15. Oct 27, 2023 at 5:43 PM
    gearcruncher
    So just the o ring was replaced ?
    You could pop the bolts off that cover and feel how hard that metal clad seal is . Look for cracks in the seal . Is the garter spring still inside the seal ? Kinda hard to tell from the pic
    4x4spiegel and HondaGM like this.
  16. Oct 27, 2023 at 5:47 PM
    gearcruncher
    Any movement on the transfer case input shaft ?
    Ricardo13x likes this.
  17. Oct 27, 2023 at 5:53 PM
    Levy49
    Too many to list
    When I had it out I didn't feel anything but then again I wasn't looking for it, and with that metal clad seal I figured if it was leaking it would be just going into the trans and not make an external leak but I did clean it off, it didn't feel brittle when I was moving it around and the spring was still intact/in place
  18. Oct 27, 2023 at 5:54 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    May want to address that cracked vent hose while your there too:thumbsup:
  19. Oct 27, 2023 at 5:57 PM
    Levy49
    Too many to list
    Now your being picky eh? XD I did trim it the first time I had it out so all good now!
    I do have this exploded parts diagram any idea what the rest of the part number would be for that rear plate? (33102E)
    Dm93[QUOTED] likes this.
  20. Oct 27, 2023 at 5:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well if you get water in the transfer case or actuator you will have bigger problems than a leak:D
    HondaGM likes this.
