leak from the exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Mar 27, 2012.
  1. Mar 27, 2012 at 1:20 PM
    bra
    bra [OP] Well-Known Member
    2008 TRD sport access cab
    Smoked headlights with White DTRL, Michelin
    Hello guys, I recently installed a magnaflow exhaust on my 2008 toyota tacoma and don't really like the sound of the new exhaust, it's really not close to a v8 engine...
    So I checked if i didn't have any leaks, and this morning when I started a found a leak on where you bolt. Water condensation I think.
    I tried to screw it again but it was the maximum already...
    What do you think is it normal?
  2. Mar 27, 2012 at 3:26 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    itll never be close its a v6. is there a new gasket in there?
  3. Mar 27, 2012 at 3:39 PM
    ironman_jon
    ironman_jon Well-Known Member
    Jonathan
    Prerunner Sport
    URD TCAI Wicked Flow 18" 2 10in alpine type r 1500 watt amp MB 72 matte black Custom Bumper Debadged Glassworks fenders McNeil bedsides Helix TB Spacer Intake Manifold Spacer Custom Roof Rack 5x 55w HID SK2 projectors 55w DDM 5k Bulbs Camburg Long Travel Fox Coilovers
    I has my TRD installed by Toyota and mine has black exhaust soot in the same area. Toyota tech said its due to that area being a "flex" joint.
  4. Mar 27, 2012 at 7:50 PM
    bra
    Gasket? No, there isn't and there wasn't on the original one...
  5. Mar 27, 2012 at 7:50 PM
    bra
    So we need tu put a joint?
  6. Mar 27, 2012 at 7:59 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Go get a replacement gasket from Toyota. They're not that expensive (generally under $20). Unbolt it, scrape off both sides, put new gasket, and bolt up both sides evenly (slowly turn in both sides bit by bit) to get the best seal.
  7. Mar 27, 2012 at 8:59 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    There is no gasket in that area if I remember correctly. You could loosen up the bolts and reposition it a bit as it is not reall center (up-down) wise. I usually coat seals like that with anti-sieze to lubricate and then torquge accordingly. This will allow the joint to slide as you torque it and provide a seal between the metal surfaces.
  8. Mar 27, 2012 at 10:41 PM
    1GR
    Scott
    BC, Canada
    Yes there is a gasket there. A donut gasket. I'd take a picture of one, but I am currently off work due to a work injury.
  9. Mar 27, 2012 at 10:49 PM
    BUZZCUT
    Georgia
    2007 AC TRD OFFROAD
  10. Mar 27, 2012 at 10:51 PM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2016 MGM TRD OR 4X4 DCSB
    Tint
    RTV on the inside.............JK
    Get a new gasket
  11. Mar 27, 2012 at 10:53 PM
    1GR
    Scott
    BC, Canada
    13th picture down. Flange still on the truck. That's a gasket. If I had a picture it would make more sense. Chances are they reused the gasket. Usually holds up fairly well. Take it from someone who has replaced this exhaust MANY times as a PROFESSION. There is a gasket there.
