Leak in Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomERRRR, Apr 6, 2018.
  1. Apr 6, 2018 at 6:58 PM
    TacomERRRR
    TacomERRRR [OP] New Member
    I just bought a 2011 Taco, and noticed damp carpet underneath each floor mat in the cab. It’s a reg cab. Water must be coming from top of vehicle because they are wet without me driving in the rain. So it’s not splashing up.
    I have lifted up the carpet on passenger side and no clue where the water is coming from.
    Any help or is this a common issue?
  2. Apr 6, 2018 at 7:46 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Check the a/c drain on the fire wall. May be plugged.
    Key-Rei likes this.
  3. Apr 6, 2018 at 7:48 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Most likely the A/C.
  4. Apr 7, 2018 at 8:50 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    BassAckwards likes this.
  5. Apr 7, 2018 at 10:05 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did it just get detailed? They may have gotten a little crazy shampooing the carpets and it never got a chance to dry out
  6. Apr 7, 2018 at 12:48 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    You shouldn’t take a leak in the cabin of your truck, that’s what the woods are for :poking:
    That said, probably just a clogged a/c drain. Poke a stick up there to clear it out.
  7. Apr 7, 2018 at 12:51 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    If it's a new to you used vehicle check the firewall in the engine bay, potentially there are penetrations for passing through wire (like for an amplifier) that were not sealed when the previous owner or the dealer removed the equipment.
    I've run into this issue rather frequently with a new used car coming in for repair.
