Leak in evaporator core
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justin144, May 12, 2020.
  1. May 19, 2020 at 10:23 AM
    #41
    justin144
    justin144 [OP] Well-Known Member
    justin
    Las Cruces, New Mexico
    2011 Taco 4X4 Dbl cab Long Bed
    hm, okay so it’s built into the condenser... I’ve had my evap core off the truck for two days. Do I need to replace the condenser since the system has been “open?” for a while? I talked to one of the mechanics at Toyota and he didn’t mention anything about replacing the condenser
  2. May 19, 2020 at 8:16 PM
    #42
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    justin144[OP] likes this.
  3. May 20, 2020 at 8:04 AM
    #43
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would say yes, but I defer to Curt he is the man for all things AC related.
  4. May 20, 2020 at 8:11 AM
    #44
    justin144
    justin
    I ordered a new evaporator core, expansion valve, condenser, oil, and o-rings last night. Hopefully that was wise! Haha
  5. May 20, 2020 at 10:55 AM
    #45
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Sorry for the delay, I'm old and forgetful. :(
  6. May 20, 2020 at 11:01 AM
    #46
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
  7. May 20, 2020 at 11:04 AM
    #47
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Yes the dessicant in the drier is most likely saturated. It is built into the condenser, so you have to replace the condenser. Brilliant idea Toyota! Not.
    justin144[QUOTED][OP] likes this.
  8. May 20, 2020 at 11:05 AM
    #48
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    This is the first time I've seen you post something that is incorrect. ;)
  9. May 20, 2020 at 11:19 AM
    #49
    Jimmyh
    SC
    2012 Prerunner SR5
    That made me laugh!
    :rofl:
    CurtB[QUOTED] likes this.
  10. May 20, 2020 at 11:21 AM
    #50
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I've seen maybe a handful of TXVs go bad, but they can. Might as well change it while you're at it. I think you got this.
    A few things to remember:
    Keep everything as clean as you can
    Keep the caps on the condenser til you're ready to hook up the lines to it. Do it last.
    Put 1oz of oil in the inlet of both the cond and evap, and try not to expose the oil to air any longer than you have to.
    If you use vacuum holding as a leak test.... :annoyed: But it's better than nothing. If it holds, turn the vac pump back on for another hour or so. Longer is always better.
    That's all I can think of right now. Good luck.
    Clearwater Bill and Jimmyh like this.
  11. May 24, 2020 at 6:12 PM
    #51
    justin144
    justin
    Got everything back together and now my air bag light is on. Dammit.
  12. Jun 2, 2020 at 2:40 PM
    #52
    OleTaco
    OleTaco Active Member
    Oklahoma
    2013 Tacoma 4wd Doublecab 4.0
    @justin144
    following your thread as I am fixing to dive in this weekend hopefully and change out the thermistor on the evaporator.
    curious if you have any pics of the actual sensor on the evaporator? I have seen drawings but looking for an actual pic. I’ll take any additional pictures you have for reference!
    Any advice to taking the dash apart? How long did it take you?
    Thanks in advance!!
  13. Jun 2, 2020 at 3:09 PM
    #53
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    If you guys end up doing this could you take some photos of the HVAC shroud and how the evap and heater cores mount inside in relation to another?
    OleTaco likes this.
  14. Jun 2, 2020 at 9:27 PM
    #54
    justin144
    justin
    I apologize, I did not take many pictures, and don’t know how good the ones I took are for reference. I had someone helping me and didn’t wanna take too much of their time lol. But I uploaded them all here: https://imgur.com/gallery/wLz9ZOO
    I did it over the course of a few days. Depending on how much of your dash you’ve taken apart before, it might take 5-6 hours to get it all out. I tried to take some shortcuts like not disassembling the steering column, and not totally removing the wiring harness and it very difficult to remove the giant crash bar, which is attached to the giant A/C unit. You’ll wanna both both those out together.
    I don’t have pics of that sensor. But you can see it when you open up the box where the evaporator core is
    mikalcarbine likes this.
