Leak near trans.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by will55, Oct 14, 2019.
  1. Oct 15, 2019 at 3:25 PM
    will55
    will55 [OP] Well-Known Member
    Will
    2019 Access cab trd off-road 4x4
    Think I’m going to give the high mileage blend a go to see if it atleast temporarily fixes it.
    I mean it can’t hurt to try right?
  2. Oct 15, 2019 at 3:25 PM
    eon_blue
    Azusa, CA
    Can't hurt to try, at the very least now you've got fresh oil lol.
    I don't know how much time it takes for it to effect the seals so you might have to give it some time, if it helps at all.
  3. Oct 15, 2019 at 3:30 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I had a similar situation it was the oil pan plug a little loose and had some blow back covering the front of the trans pan
  4. Oct 15, 2019 at 3:32 PM
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    MY rear main seal leaked when it did that
  5. Oct 15, 2019 at 3:32 PM
    will55
    Will
    Would definitely rather pay for an oil change then the labor costs for replacing the 30$ seal.
    I’ll keep that in mind. Really hope it works (Even if it’s just temporary)
  6. Oct 15, 2019 at 3:33 PM
    BillsSR5
    bill
    2014 SR5
    what causes that, overfilling the engine oil?
  7. Oct 15, 2019 at 3:35 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    usually 75k+ seals starts getting shot. Its common.
    BillsSR5[QUOTED] likes this.
  8. Oct 15, 2019 at 3:35 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    Usually cost from 600-1000
  9. Oct 15, 2019 at 3:35 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    will55[OP] likes this.
  10. Oct 15, 2019 at 3:36 PM
    will55
    Will
    Interesting. Unfortunately I checked the “view window” (small piece of plastic you pull off on the bottom of the trans) and there was oil on the inside. From what I’ve read that’s most common with a rear main seal leak. Definitely could be wrong I’m still very new to this.
    Jimmyh likes this.
  11. Oct 15, 2019 at 3:38 PM
    will55
    Will
    Did what? Like it had oil in a similar area as mine?
  12. Oct 15, 2019 at 3:39 PM
    will55
    Will
    Will definitely keep that in mind. Thanks
    Delta09[QUOTED] likes this.
  13. Oct 15, 2019 at 3:41 PM
    BillsSR5
    bill
    2014 SR5
  14. Oct 15, 2019 at 3:45 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    yupppp
  15. Oct 15, 2019 at 3:56 PM
    #35
    will55
    Will
    Ya. I’m almost certain it’s a main seal leak.
    Will know for sure tomorrow.
  16. Oct 15, 2019 at 4:05 PM
    #36
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It can, yes, though the solution to stopping that leak is draining out the excess and cleaning the residual oil down below. That usually takes care of those types of leaks.
  17. Oct 16, 2019 at 8:15 AM
    #37
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP... honestly wouldnt worry about it too much. I had an old chevy that had a rear main seal leak so bad that it would loose ~ 1qt of oil ever 1k miles (some of which was due to blow by). I just figured it was more rust prevention under the truck.
    BassAckwards likes this.
  18. Oct 16, 2019 at 7:03 PM
    #38
    will55
    Will
    Hahahahah
    Took it in today to the shop my family and I have been using for almost 16 years. The guys there quoted me a price I’m fine paying. I know the leak probably won’t ruin the truck but I do know it will drive me crazy every time I think about it.
    Taking her in on monday morning.
  19. Oct 16, 2019 at 7:35 PM
    #39
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No.
  20. Oct 16, 2019 at 7:52 PM
    #40
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Get it fixed and be happy again.
