leak on drivers side floor
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcbe6472, Sep 19, 2010.
  1. Sep 19, 2010 at 8:56 AM
    tcbe6472
    tcbe6472 [OP] Well-Known Member
    Tommy
    Lake Jackson,TX
    09 TRD
    Got a leak on the drivers side floor board of my 01 and can't figure out where its coming from?? I replaced the damaged weatherseal around the door, sealed the rubber plugs in the floorboard with silicone and its still leaking?? Can anyone offer some feedback or advice? Short of tearing out all of the interior, Im at a loss..
  2. Sep 19, 2010 at 6:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Had a lot of rain lately? Could be leaking around the windshield seal.
  3. Sep 19, 2010 at 11:23 PM
    02tacoma2.7
    02tacoma2.7 Well-Known Member
    Barrett
    Albany, Ky
    02 tacoma 2.7 4x4
    K&N cold air Eagle 102 15x10 wheels 31x10.50x15 Cooper STT Line-X rocker planels Window Tint
    I have the same leak but i cant seem to find the leak either. i thought it might be comeing in around where i cut some of the inner fender. but i can see why it come in there when my truck in sitting over night?
  4. Sep 19, 2010 at 11:28 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    my truck leacked at the top driverside corner of windsheild, it preceded to flow down the pillar and on to the floor
  5. Sep 20, 2010 at 2:21 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i had a brand new 2010 that done that. when i went to get the truck that i have now i needed to clean out the leaking truck. they had the wipers off and that black cowl thing under wipers. they seemed to think it was leaking at the bottom of windshield and top of firewall.
  6. Nov 8, 2010 at 9:14 AM
    MikeyDo
    MikeyDo Active Member
    North Little Rock
    98 Tacoma 4WD
    I found an elusive leak that came in where a portion of the wiring harness penetrates the firewall. Turns out that the body seam sealer above it had a nib in just the right place and the black goo around the penetration had separated. The combination of these things allowed a steady drip of water to go right into the corrugated wire wrap stuff (whatever it's called) and run into the cab. Some generic black goo from Advance Auto Parts and no leak since.
    Have someone pour water over your windshield and watch what happens under your dash. This is how we diagnosed it.
  7. Nov 8, 2010 at 9:33 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    Yep mine leaked too right where the wires came thru the fire wall, sealed it with silicone and it stopped.
