Leakage
Discussion in '1st Gen. Tacomas (1995-2004)' started by low12, Sep 29, 2009.
  1. Sep 29, 2009 at 10:38 AM
    low12
    low12 [OP] Active Member
    RUFFIAN
    Virginia
    Prerunner SR5 V6
    My '04 CrewCab V6 is having some oil leakage but I can't pinpoint where; the area by the air filter, serpentine belts,under the hood is where much of the oil is visible; its on the passenger side. Does anyone have this problem before? Thanks for your much awaited response.
  2. Sep 29, 2009 at 2:22 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    could it be cam seals?
  3. Oct 5, 2009 at 10:08 PM
    swsteven
    swsteven Well-Known Member
    houston tx
    2001 tacoma trd
    3 inch lift bilsteins and aal 16 inch pro comp wheels, m/t tires
    maybe ur powersteering pump
  4. Oct 6, 2009 at 5:29 AM
    low12
    RUFFIAN
    Virginia
    Prerunner SR5 V6
    Thank you for your response, and I think you're diagnose is about right due to the oil leaks is clear in appearance and in the area of the power steering reservoir. Thanks again. Have a good day.
