leakdown test shows exhaust valve leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Mar 17, 2013.
  1. Mar 17, 2013 at 5:19 PM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    I have been having a code of P0303 which is a cylinder #3 misfire.
    I just had a leak down test done.
    The mechanic indicated that I had leakage of 10% on #1 cylinder, 35% on #2, 40% on #3 and 20% on #4.
    He indicated that the combustion chamber leak-down is exiting through exhaust valves.
    Will a new cylinder head fix my troubles?
  2. Mar 17, 2013 at 5:47 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    How did he know it was specifically the exhaust valves? A rate of decay test is only qualitative.
  3. Mar 17, 2013 at 7:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If it truly is the exhaust valve(s) its because they're burnt most likely, I'd thoroughly check the head for cracks/warp/etc: before shit canning it for a new one & no a new head won't change anything unless its been rebuilt
    (if i'm understanding you right)
  4. Mar 17, 2013 at 7:09 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    What I'm trying to determine is if a new (or most likely rebuilt) cylinder head would fix my problems based on the data that I have or is more data needed.
  5. Mar 17, 2013 at 7:11 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    From what I have read, when performing a leak down test, if you hear air hissing out of the tailpipe or exhaust manifold this means an exhaust valve leak. I would assume that is what the mechanic did.
  6. Mar 17, 2013 at 7:13 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    This would be correct.
    You could try sourcing a new head but then unless it's rebuilt you still don't know for certain what you're gonna get, why not pull yours and have it checked out and see what can be done.
  7. Mar 18, 2013 at 6:06 AM
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Pull yours and send to machine shop they can also replace the valve for you too. Most wont set your valve clearance though
  8. Mar 18, 2013 at 10:04 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Cool.
    I would most definitely rebuild what you have rather than buying some Chinese Advance Auto Parts special that won't last 24 months.
