Leaked Transmission Fluid Concern
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slobber, Jun 15, 2020.
  1. Jun 16, 2020 at 12:20 PM
    Slobber
    Slobber [OP] Well-Known Member
    Central PA
    2015 Pyrite DCSB
    I was waiting for the oof. I am concerned with anyone touching my truck, especially a Jeep dealer also. But I found out that a guy there worked at Toyota until a couple of years ago, I called and verified this before going and after talking about the trucks I was feeling confident.
    I just heard from them. They did overfill it and fluid was coming from the vent line. The line was split and was just coming out the whole length of it. Sure enough, they admitted that the Toyota guy was working on another truck when mine was being finished.
    Lesson learned for me. Oof
  2. Jun 16, 2020 at 12:27 PM
    durtkillon
    durtkillon Well-Known Member
    Kurt
    Fort Collins, CO
    2010DCLBV64X45SPAT 1E7 BASE
    Sickest Mod: Synthetic Oil
    I had this issue with my Jeep. The cause was that the trans was overfilled and it seeped out a weep hole every time it got hot. Perhaps they did not verify the level at the proper temperature. The fluid check is WAY lower than the fill port. If the procedure is not followed properly, it's easy to overfill it.
  3. Jun 16, 2020 at 12:37 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Thanks for reporting back, it will help someone else in the future.
    Slobber[QUOTED][OP] likes this.
  4. Jun 16, 2020 at 1:07 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Man, id be leery of the potential damage done to seals of the trans due to over filling.
  5. Jun 16, 2020 at 2:26 PM
    Slobber
    Central PA
    2015 Pyrite DCSB
    I’ll keep you posted
