Leaking after ECGS replacement.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dubdaddy86, Aug 17, 2021.
  1. Aug 17, 2021 at 3:16 PM
    Dubdaddy86
    Dubdaddy86 [OP] Well-Known Member
    It’s been 3 days since installing my lift and replacing the needle bearing. Just today I noticed it’s leaking. Before I dive into it, what’s the normal prognosis? Issue with the axle seal? I’m just trying to get an idea of what I’m looking at before I get into this project.
  2. Aug 17, 2021 at 3:32 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  3. Aug 19, 2021 at 6:25 PM
    Pit Snipe 1997
    Pit Snipe 1997 Well-Known Member
    Scott
    Maryland
    2021 Cement Tacoma Off Road
    Bed lined the rear bumper caps, LED lights in the interior, rear bed LEDs, red letter glove box inserts, center console coin box, set of Wildpeaks from my 2014 Tacoma that I traded in and removed the factory running boards.
    you have to make sure the oil seal is sitting back 5.5 millimeters from the face of the opening where the CV joint mates to the front differential.
  4. Aug 20, 2021 at 5:38 AM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    I used a large socket on the flat side to seat the seal, it sits flush. Zero leaks @ 42k miles so for.
  5. Aug 20, 2021 at 5:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    BTDT. I drove the seal a bit too far in and had a murder scene under the Taco. Get a new seal and only go to flush with the face of the diff.
  6. Aug 20, 2021 at 5:42 AM
    bigmace
    bigmace Well-Known Member
    Salem, OR
    2020 DCLB SR5 4x4
    Seems like the only issue it could be is a damaged or improperly installed seal.
