Leaking again badly [was: Update: on my truck with leaking diff [was: few things I noticed...]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eden4x2, Jun 10, 2016.
  1. Aug 17, 2016 at 7:29 PM
    #41
    Eden4x2
    Eden4x2 [OP] Well-Known Member
    Yup.. driving down the road, howling noise graduated to a loud crunch, and jerked violently and stopped on the freeway. All the lights on my dash lit up like christmas and was gone. I was going about 60, and came to zero in couple of yards. Engine died. I was terrified. On this freeway nobody follows speed limits, and every day there's a grave accident. I tried to push the start button couple of times. I will tell you one thing I learned the hard way. There is nothing like having a key and that nice cranking sound. With this fancy push start, I keep pushing it and nothing happens for a seconds which felt like eternity all the while my heart is beating outside of my chest. It finally started and I drove to the side, nearly colliding with another car as I was trying to switch lanes from the far left to right side buffer lane. This truck was at the dealership with this leaky problem for almost a month :(, aannd it's back there again. and they gave me their corolla to drive home. icing on the cake. -e
    smitty99 likes this.
  2. Aug 17, 2016 at 7:37 PM
    #42
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Holy crap that's scary. I'm with you on the key ignition......I'm just glad you got off the highway safely!
  3. Aug 17, 2016 at 7:42 PM
    #43
    USDashCamera
    USDashCamera Put it in H
    2017 Quicksand TRD OR
    Damn that sucks. The last I heard from you you were all excited about all the stuff you bought for it. hope things get sorted out. has there been any other horror stories this bad on the 3rd gens?
    Lawfarin likes this.
  4. Aug 17, 2016 at 8:14 PM
    #44
    TOY33
    TOY33 Well-Known Member
    Silver 14 DCSB PreRunner
    Not acceptable ... hope you end up with a 17 upgraded model on Yotas dime.
    Sub'd for outcome
  5. Aug 18, 2016 at 6:04 AM
    #45
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
  6. Aug 18, 2016 at 6:51 AM
    #46
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Sounds like your diff may have exploded on you after running for so long with no fluid...if it did, you are lucky you didn't get into an accident.
    Toyota has quite a bit to do for you here....
    And screw that if you don't want a corolla call toyota corporate and explain everything that happened and that you want a truck to drive while it's in the shop. You paid for a truck or are making payments on a truck, not to be out of one for almost 60 days total (if this is differential related). The first time it happened, ok at least they put you in a rental, but second time?? It's time for them to start stepping things up for you. If your differential exploded, toyota replaced it and endangered you on the highway, they should be happy to cater to you to avoid a lawsuit and/or lemon law.
  7. Aug 18, 2016 at 7:25 AM
    #47
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    2016 Blk TRD Sport 4X4 DCSB
    Cracked W/S
    Edit: Scrapped
    Best of luck to you OP.
  8. Aug 18, 2016 at 7:32 AM
    #48
    wachuko
    wachuko Well-Known Member
    Orlando, FL
    WTB-2019 Tacoma Double Cab TRD Off Road 4x4
    Please, do yourself, and everyone else, a favor and log a complaint with the National Highway Traffic Safety Administration (NHTSA):
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
    It is the only way for these problems to be raised and pushed to be made recalls... everyone that is experiencing these issues should file a claim. Only way to push Toyota to recall and fix these issues...
  9. Aug 18, 2016 at 9:16 AM
    #49
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Why was your diff pressurized?
  10. Aug 18, 2016 at 9:42 AM
    #50
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    Just pulled the vent fitting. It's actually a check valve. Let's air out but not in. I was probably hearing the vacuum release rather than air escaping. Mine is working fine.
  11. Aug 18, 2016 at 2:39 PM
    #51
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    You should send these messages to Toyota and a lawyer.Anew truck is not soppose Kill You!!!!Again good luck keep us informed.
  12. Aug 18, 2016 at 3:10 PM
    #52
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    Damn....I hope Toyota does the right thing and really hooks you up!
  13. Sep 3, 2016 at 5:14 AM
    #53
    smitty99
    Scottsdale
    Update?
  14. Sep 3, 2016 at 6:21 AM
    #54
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    This problem sounds like a failed carrier bearing (perhaps from low fluid or misallignment with the axle shafts), followed by a ring and pinion misalignment (from bearing galling), then catastrophic gear failure.
    ZachMX likes this.
  15. Sep 3, 2016 at 6:25 AM
    #55
    bradwhitenikki
    Brad
    I am not sure how Toyota sets the pinion depth, but I have seen problems there with poor pinion preloading hardware changing the preload and throwing the backlash out. Eventually the pinion depth could go far enough out, and open the backlash to critical levels.
    ZachMX likes this.
  16. Sep 3, 2016 at 6:28 AM
    #56
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Ain't staking the pinion nut?
    ZachMX likes this.
  17. Sep 3, 2016 at 6:29 AM
    #57
    bradwhitenikki
    Brad
    Good point. I've seen that too.
    ZachMX likes this.
  18. Sep 3, 2016 at 6:36 AM
    #58
    bradwhitenikki
    Brad
    I am quoting a Ford 9 inch rear end guru:
    "A common problem is worn carrier bearings, as indicated by a low-pitch rumble above 20 mph. On vehicles with C-clip axles, the noise may vary while negotiating turns. Worn pinion bearings can cause whirring noises at all speeds, under deceleration and/or acceleration. Pinion bearings tend to whir, rather than rumble, because the pinion is turning several times faster (depending on gear ratio) than the carrier. Badly worn bearings can also cause howl if they do not support the gears correctly." Randy's R&P
    ti3agooo, Biblite and smitty99 like this.
  19. Sep 9, 2016 at 5:56 PM
    #59
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Just checking in E and seeing how everything is going?
  20. Sep 9, 2016 at 7:15 PM
    #60
    aero90
