Leaking ball Joints
Discussion in 'Suspension' started by paulmars, Jul 21, 2009.
  1. Jul 21, 2009 at 2:33 AM
    paulmars
    paulmars [OP] Well-Known Member
    Only 20k miles, no off road. Normal? Tks, Pa
  2. Jul 21, 2009 at 4:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    According to your profile, you have a 2003?? Or no??
    Did you inspect the little rubber boots? Are there any cracks, rips?
  3. Jul 21, 2009 at 10:13 AM
    paulmars
    Yes 2003 2wd. No cracks. Leaking out where the rubber meets the metal. Started before 20k miles and each time I look more grease has leaked. One joint is all greasy and along with the road dirt that sticks to the grease.
  4. Jul 21, 2009 at 10:14 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  5. Jul 21, 2009 at 10:54 AM
    paulmars
    Im due to rotate next weekend, and I'll try get some pics. Just leaking where rubber meets metal. Leaking more and more over the months.
  6. Jul 21, 2009 at 3:55 PM
    Janster
    Jandy
    Lancaster, PA
    Not too familiar with taco balljoints myself...just ran out and looked at my 07 quick.
    Does the 03 have a grease zerk at the top? If YES - then the best thing you can do is wipe off the grease and keep adding grease. This will keep the balljoints 'fresh' & lubricated.
    If you don't have a grease zerk - then....I doubt there's anyway of 'sealing' the rubber to prevent it from leaking. The rubber might be somewhat dry rotted and why its leaking. At this point...it's only a matter of time before the balljoint can dry out & cause problems.
    It might last a long time like that...I honestly don't know. You just have to keep an eye on it OR bite the bullet and have it changed. Take it to some different garages and see what they'll charge you to change it. Then...you can make your own decision whether to get it replaced now or wait.
  7. Jul 21, 2009 at 4:23 PM
    paulmars
    No, mine does not.
    Started in the second year of ownership(2005). Bought new. Not dried out yet, but still oozing. Dealer service said its fine, normal, and expected, Called Toyota and they said, this is bad and sent me to dearer service, who said again, that its fine. Called Toyota and they were going to send me to another dealer, but never called back.
  8. Jul 21, 2009 at 4:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its not "Fine", and they should be inspected, and/or replaced.
  9. Jul 21, 2009 at 5:12 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    try a GOOD grease.my jeep "leaks" when its hot and humid setting in the garage ,out of the zerk.i use what ever grease i have for that thing.
