Leaking battery acid all over
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Art411vm, Jan 25, 2019.
  1. Jan 25, 2019 at 7:50 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    That will only work if the battery is under warranty. I’m
    I would go to like an autozone and get a bottle of gunk degreaser.
    Let the engine bay cool fully and spray it all over and let it hang out for a few minutes (don’t leave it there long enough to dry).
    Hose it out and get yourself some car wash soap and warm water with a long soft bristled brush. Dip the brush in the water and start cleaning every nook and cranny.
    Rinse well and dry.
    The painted metal shelf that holds the battery, if thats rusted I would be wire brushing it, hitting it with a rust coverter and respraying it with maybe a primer or you can get a paint matched paint. Its under the hood so you don’t see it.
    If you want you can buy a plastic and rubber dressing to treat all of your rubbers and plastics. This helps keep things from cracking and getting eaten up from salt.
  2. Jan 25, 2019 at 7:51 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    You qualify for battery replacement under warranty if they test it and it fails. Otherwise, clean it up and hope it fails before your warranty expires.
    I’d be monitoring for the next group buy by @ramonortiz55 for a Northstar battery :thumbsup:
    Let’s Go :D
  3. Jan 25, 2019 at 7:52 AM
    PackCon
    Connor
    I just monitor my battery terminals. If they are showing signs of corrosion then its time to kick the battery to the curb. All batteries leak gas as they age, its an easy indicator to tell you to replacd it before it dies.
    I typically don’t disconnect the battery to clean the terminals except when I change the battery.
    I keep my engine bay very clean (detailer) so my terminals get cleaned as I go.
    Mully likes this.
  4. Jan 25, 2019 at 7:53 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Google battery cleaning. Bunch of info out there. Yes, disconnect both cables. There is a tool you can get from many places to scrub the terminals and cable ends to get a clean connection. The only concern is that be careful with tools around the battery. Accidental contact between + and chassis (or - terminal) can be dangerous. Read up on it.
    Hobbs likes this.
  5. Jan 25, 2019 at 7:53 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Yes, and get a wire brush that can clean the inside bore of the clamps. Corrosion likes to hang out in there.
  6. Jan 25, 2019 at 7:56 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Warranty for sure. The dealership replaced the 18 month old battery on my previous 2012 PreRunner under warranty. It had way less corrosion than is showing on yours. They never batted an eye. Just took one look and snap, had a new battery.
  7. Jan 25, 2019 at 8:06 AM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Baking soda and water mix. And soon.
  8. Jan 25, 2019 at 8:10 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Replace it with an AGM battery and send the bill to Toyota
  9. Jan 25, 2019 at 8:19 AM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    This actually work or you messing with us?
  10. Jan 25, 2019 at 8:25 AM
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    That is what happens when the truck goes off-roading. all the battery acid sloshes around and leaks out of the caps and on to the terminals.
    If you don't like it I suggest doing a search on an AGM battery as they do not have this issue.
    Ask me how I know.
  11. Jan 25, 2019 at 8:29 AM
    DansSr5
    do you have a can of coke? Brand name cocacola. pour it on the corrosion and it will eat it up. rinse with water. Unplug the terminals, clean them with a terminal cleaner. Put the battery terminal grease on the connectors. and reconnect it.
    r1200gs4ok likes this.
  12. Jan 25, 2019 at 8:32 AM
    DansSr5
    Kinda hard to explain without showing you. look at youtube and you will see what everyone is talking about. I always youtube or google before asking for help. and then i usually don't have to ask for help after that.
  13. Jan 25, 2019 at 8:34 AM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    :anonymous:
  14. Jan 25, 2019 at 8:35 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    mine looks like this..
    Mully[QUOTED] likes this.
  15. Jan 25, 2019 at 8:43 AM
    #35
    Grossomotto
    2017 4WDV6LB6MT
    There’s members here that have sent the new battery receipt to Toyota and got a prorated refund, so it does work
  16. Jan 25, 2019 at 8:46 AM
    #36
    Art411vm
    Art411vm [OP] Member
    Bradley
    West Virginia
    2017 Toyota tacoma
    I have never taken it off road. Just drove it across the country.
  17. Jan 25, 2019 at 8:48 AM
    #37
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Do you drive in areas that use road salt in the winter? That looks like more than just battery acid corrosion.
  18. Jan 25, 2019 at 8:50 AM
    #38
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Thats not acid,its anti corrosion,try cleaning the battery up ever so often.you need to service/clean them like everything else on your truck.
  19. Jan 25, 2019 at 8:50 AM
    #39
    DansSr5
    Same here. Very light offroading. I have 24k miles on the truck and have had to clean up terminals twice as well as top off the battery with distilled water. AGM battery will be next.
  20. Jan 25, 2019 at 8:53 AM
    #40
    Art411vm
    Bradley
    West Virginia
    2017 Toyota tacoma
    Yes but it 1 Weird it's not all over the other parts of the engine just that little area
