leaking behind this plate.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowgod06, Feb 7, 2011.
  1. Feb 7, 2011 at 11:41 AM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    So can anyone tell me what this plate covers, and what perhaps is leaking from around it?
    Circled in red is the plate itself, circled in yellow is where it is leaking.
    This plate is near the power steering pump, in the picture you can see the belt to the right of my finger going to the pump.
  2. Feb 7, 2011 at 11:57 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I believe its called Timing Chain Cover Plate
    if it is leakign from there make sure bolts are tightened to spec, Or you can always remove bolts and replace gasket.
  3. Feb 7, 2011 at 12:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^^
  4. Feb 7, 2011 at 12:13 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    06 TRD Prerunner
    There's a TSB for that. It's covered by the 6/60 power train warranty.
  5. Feb 7, 2011 at 1:03 PM
    snowgod06
    Rob
    06 Access Cab
    Thanks guys, i had a feeling it was that after talking to another member yesterday. Thanks for the input, guess a trip to the dealership is coming.
