Leaking Differential Question for Mechanics
Discussion in '3rd Gen. Tacomas (2016-2023)' started by harrycary, Aug 9, 2017.
  1. Aug 9, 2017 at 5:00 AM
    harrycary
    harrycary [OP] Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Hi all. I am reaching out to you mechanics and those with past experience.
    First, why do you think these leaks are happening? For example, I have a 2016 TRDOR that is seeping. I am not on the recall, and I checked the torque of the 3rd member studs. They are not loose. Is it the fluid's viscosity? Is the gasket junk? Is the axle tube housing warping?
    Second, has this happened to the previous generation rear axles? We're the 2nd gen axles made by Hino also?
    Thanks!
  2. Aug 9, 2017 at 5:55 AM
    Kirk5370
    Kirk5370 Well-Known Member
    Toronto, Ontario
    2017 DCLB TRD Sport +
    Clazzio, Weatherbeaters, Softopper
    If it is an assembly, a mechanic may be able to help you. However, I don't think this is related to assembly. The suspect number of trucks is way too large to be a supplier assembly problem; even the worst suppliers have to perform mandated torque checks on fasteners. I suspect this is a better question for an engineer. Maybe it is a design issue, but really no one knows except toyota corporate.
    IMO, a tolerance issue (improperly toleranced), or a stack-up issue (when the sum of the difference in tolerance ranges between a variety of parts add up to one that is out of specification)
    Could be the housing, could be the gasket, not likely to be related to fluid as they don't change much and are used on multiple vehicles. Generally you have good supplier support.
  3. Aug 9, 2017 at 5:56 AM
    harrycary
    Harry
    Great information Kirk.
  4. Aug 9, 2017 at 6:21 AM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Didn't they narrow down the problem to the studs? Something about them being out of spec or made from a softer that acceptable metal?
  5. Aug 9, 2017 at 6:41 AM
    Cheers007
    Cheers007 Well-Known Member
    DFW
    2017 Tacoma Limited
    subbed
  6. Aug 9, 2017 at 4:41 PM
    madmanxing
    madmanxing Well-Known Member
    2017 Cement Tacoma Trd Pro
    interested also as i noticed seeping on my truck yesterday morning and have to go through this whole mess now.:(
    shakerhood likes this.
  7. Aug 9, 2017 at 4:43 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    2nd gens have not had this problem. The axles are not the same though I'm not sure if made by the same company
  8. Aug 9, 2017 at 6:23 PM
    harrycary
    Harry
    I am pretty sure the 3rd gens thinned out the axle tube metal. The third member, of course, mounts to this thinner assembly.
