Leaking firewall
Discussion in '1st Gen. Tacomas (1995-2004)' started by tarheelfan_08, Dec 26, 2008.
  1. Dec 26, 2008 at 1:53 PM
    tarheelfan_08
    tarheelfan_08 [OP] Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    So recently I have been smellin something in my truck! And upon further investigation today I figures out it was my carpet! There is a leak in my firewall and the carpet is soaked! Does anyone got ideas on how to fix this! Cause I have to wait till Monday to go to my bodyshop!! Currntly the carpet is rolled back on the passanter side drying out with windows cracked to get rid of smell!!!!
  2. Dec 26, 2008 at 1:55 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    where exactly is a firewall and what is it
    well if its a hole lettin water in duct tape as a temporary solution?
    go heels!
  3. Dec 26, 2008 at 1:57 PM
    tarheelfan_08
    Justin
    North Carolina
    It is on the passanter side inside the engine area !! It looks to have factory seelent on it! But is starting to go away!
  4. Dec 26, 2008 at 1:58 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Is it water or coolant? If its water your gonna have to find the source and fill it with silicone or caulk. If its coolant then you got a heater core leaking
  5. Dec 26, 2008 at 2:01 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    as a temporary solution, and temporary only.... if you cant duck it, fuck it
  6. Dec 26, 2008 at 2:04 PM
    Motoknuckle
    Motoknuckle Braaaaap!
    Caleb
    Iowa
    02 Prerunner xtracab V6
    Tint, Clear Corners,
    You seriously don't know what a firewall is?!
    The firewall is the part of the cab that separates the engine from the interior.
    Is there a rust hole? Something had to go wrong to make it leak.
    I also agree that it might be your heater core...try checking under your dash for leaks.:)
  7. Dec 26, 2008 at 2:06 PM
    tarheelfan_08
    Justin
    North Carolina
    I just took a water hose and sprayed down itno the area and sure enough it was water leaking into it! It is provally from these heavy rains!! But nothin else is close enough to it to leak but water
  8. Dec 26, 2008 at 2:06 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Thats Awesome!!! :D
  9. Dec 26, 2008 at 4:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you have coolant getting inside thru the firewall........its your heater core.............if its just water, you probably have a hole that rusted thru, or a grommet that dry rotted and is letting water get thru.
  10. Dec 27, 2008 at 6:42 AM
    rugerm44
    rugerm44 Member
    Check the rubber going around the wiring harness thru the firewall on pass side.Mine leaked there when it was new.RTV
  11. Jan 5, 2009 at 7:22 AM
    tarheelfan_08
    Justin
    North Carolina
    I got my problem fixed! I went and had it looked at and the guy told me where the leak was and how to fix it. All for free!! I guess that's the benefit of knowing a garage owner lol :D But I went home and put silicone on problem areas and the next day I washed my truck and engine and there was no leakage! Hopefully it stays like this!
  12. Jan 8, 2009 at 5:04 PM
    swsteven
    swsteven Well-Known Member
    houston tx
    2001 tacoma trd
    3 inch lift bilsteins and aal 16 inch pro comp wheels, m/t tires
    i would definitly take all my carpet out scrub it with soap then hose it down and let it hang dry , that water that was in there is growing mold in your carpet as we speak, causing a wet sock smell
  13. Jan 20, 2009 at 7:03 PM
    Rosco75
    Rosco75 Well-Known Member
    Clavet Sk
    2001 Tacoma SR5 TRD
    3 inch skyjacker lift, k&n FIPK, 33inch procomp mud terrain tires
    Hey I had a mysterious leak on the drivers side of my `01, Couldn`t figure it out, seemed like a firewall issue as well. Could not find it, I was just about to lose my mind when one night some A-hole put a bottle into my parked trucks windshield. Got it replaced, turns out it was the seal around the windshield!
  14. Dec 1, 2009 at 5:51 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    This is passenger side. is that a fresh air vent?
