Leaking Front Crank Seal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05sctaco, Mar 26, 2010.
  1. Mar 26, 2010 at 10:53 PM
    05sctaco
    05sctaco [OP] Well-Known Member
    Ken
    Santa Cruz
    So i had a leaking front crank seal for awhile now. Finally got around to changing it out. Its relatively easy but a bitch to get the right tools. No pictures since everything was covered in oil/dirt, from the crank all the way to the back of my oil pan. The seal is made of hard rubber or plastic, and the seal puller i got finally worked after taking a chunk of skin off my knuckle. There is no hammer room, and the replacement seal kit i got at kragans was a joke.....return. You'll need to get a piece of pvc pipe the same diameter as the seal, and an end cap. Drill a hole in the middle of the cap. place cap on the pcv and use that with the bolt to press the seal in. If the PVC and end cap combo exceeds 1" in length your screwed since the bolt won't be able to catch any threads. 20 min job took 4 hours. My anguish your gain. If you need to replace the front crank seal after warranty that is how you will do it.
  2. Mar 27, 2010 at 12:05 AM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    Is this a v6 and about how many miles were on it when you started to notice the oil slick?
  3. Mar 27, 2010 at 12:15 AM
    05sctaco
    Ken
    Santa Cruz
    It's the V6, I noticed it around 60,xxx, and i have about 75k right now. Checking the dipstick you can't tell you have a leak, only by looking at the area under the crank. Everything was covered in oil, dirt, and sand.
  4. Mar 27, 2010 at 12:21 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Me and my dad replaced the front crank seal on his 07 and it went like a breeze. We didnt use a seal puller or whatever its called lol. We just pulled it out with a flatblade and pliers I think. Im not quite sure why you had to go threw all of that trouble? :confused:
  5. Mar 27, 2010 at 12:30 AM
    Timber
    Tim
    San Pedro Bay Ports
    Thanks, I take it you went to Toyota for the seal after the Kragen one was determined to be crap. Good to see you did it yourself instead of paying someone else to do it.
  6. Mar 27, 2010 at 12:35 AM
    05sctaco
    Ken
    Santa Cruz
    I got the seal from toyota. I got the tools from kragens. I thought about pliers or a flat head, but this was my first ever attempt at replacing something i've never done before. Plus i didn't have anything that could press the seal in.
  7. Mar 27, 2010 at 12:43 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    We got it from Autozone. But it only leaked cause WE damaged it when installing a NST crank pulley.. :eek:
