Leaking front diff, drivers side.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meafordmike, Sep 17, 2010.
  1. Sep 17, 2010 at 4:49 PM
    meafordmike
    meafordmike [OP] Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    "Updated" last page
    So I am lifted about 1.5" (Radflo coilovers and Camburg UCA's). I have be lifted for 6 months with new 265 75 16 BFG's AT Ko's, about 3 weeks ago I put the stock sport Dunlop’s back on for a upcoming trip out east.
    When I changed my tires back to stock I started to notice a growl coming from the front end.
    At first I thought it was just my normal drive shaft vibe (Dakar’s in rear).
    But today I check and my front diff is wet with oil and lots of play in driver side axle.
    Five Questions:
    1:Whats the problem?
    2: Is the normally covered under the 60000mile/ 100000Km warranty if it wasn't lifted?
    3: how much for me to pay Toyota to do?
    4:Can I do this myself?
    5: Is there any offroad friendly Toyota dealers in Ontario Canada?
    Thanks in advance.
    Thanks Mike
  2. Sep 17, 2010 at 4:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    That should be covered under the powertrain waranty.
  3. Sep 17, 2010 at 5:02 PM
    meafordmike
    Even if lifted?
    To save some bucks I could re-install my old stock coilovers, and then just pay for the alignment afterwards.
  4. Sep 17, 2010 at 5:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The lift isnt going to affect the diff seal.
  5. Sep 17, 2010 at 5:33 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i posted in your other thread but chris is right, its covered under warranty
  6. Sep 17, 2010 at 5:42 PM
    meafordmike
    Tomorrow I will check the level after I figure out how, then top up with diff oil??( type quantity). Till I can get it in to Toyota.
    I will do some reading/ seaching tonight to figure this all out.
    I love learning how to do new stuff!!:D
  7. Sep 18, 2010 at 4:48 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    The seal itself is a very cheap fix. Don't bother swapping everything out then paying for an alignment yourself - you'll likely pay just as much or more than replacing just the seal.
    If for some reason Toyota gives you grief and won't repair, do it yourself or take to an independant shop. Shouldn't be much more than 1-1.5 hrs for a compentent mechanic to swap it out.
  8. Sep 18, 2010 at 5:38 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    ok i had this same thing just happen to me 2 weeks ago
    it is covered by the 60,000 mile warrenty
    no q's asked....
    and i am lifted as well
    good luck
  9. Sep 18, 2010 at 5:39 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    oh and as for the play in the driver side cv ...it has more play then the pass side this is normal
  10. Sep 21, 2010 at 11:55 AM
    meafordmike
    Update Sept 21 2010.
    So I got under the truck to check level of diff, it was fine. I bought a new suck gun for this and once I opened up the fill plug fluid started coming out, and then the new suck gun tube was too big to fit in the hole. So 75 90 all over me and the driveway, finally put some in and closed it up.
    Today I got into Toyota, They confirmed the diff axle seal (or whatever it’s called) on the driver’s side was leaking. But that Toyota Canada would not cover this (edit: they have to call head office but said they were 99% sure it’s not covered) as I have a lift, I was pissed! They did tell me my Transfer case was gone and they would replace under warranty . Now I had no problems with my transfer case so I am not sure if they were trying to throw me a bone for not covering the seal.
    I am not sure if I will get Toyota to replace the seal when I am in for the Transfer case or do it myself, I wish there was a "how to" tread on this (Chris 4x4?) or if I will leave it for a while and replace when it gets worse.
    Do you think it’s a good idea to get the diff drop now?
  11. Sep 21, 2010 at 12:20 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i can pull up a guide but im on school computers, pm me if noone helps
  12. Sep 21, 2010 at 12:23 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  13. Sep 21, 2010 at 12:45 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    this has occurred to me twice... toyota fixed it under warranty... but they said its due to the previous 3" lift I had. They fixed the first under warranty without question, they fixed the second because they didn't associate the busted seal with the lift during the first fix
    but who knows... everyone on TW says the lift didn't cause this. I think there is a manufacturing defect in some tacomas with this and that a lift potentially exaggerates it.
  14. Sep 28, 2010 at 1:39 PM
    meafordmike
    So I just got off the phone with Toyota Canada, and they said they won't cover the diff seal:mad:. I told some snooty lady I wanted to speak to a Tech that knows about trucks for a second opinion. The lady from Toyota told me that it’s up to the dealer to provide Toyota Canada with their recommendation on coverage. I told her I could go to another dealer and she said that Toyota has my VIN now and knows it’s lifted so they would deny further claims. I said what happened to it’s up to the dealer. I am a little mad right now, and this dealership will not get my money for repairs. I will do it myself later.
    Rant over
  15. Sep 30, 2010 at 11:57 AM
    meafordmike
    Update again.
    Toyota Canada told me to F$#$#-off today.:mad: They replaced my Transfer case but this fixed nothing. I knew it was the diff but they said it was not covered so they replaced my Transfer case for nothing. Toyota Canada will not do much of anything if you have a lift. I only have 2" of lift in the front.
    So when I got home I jacked the truck up and spun fronts wheels and can hear a click in the diff where the Diff side bearing would be.
    My driver side axle seal is leaking and I think the Diff bearing is going.
    What do you think?
    I tried to tell the dealer that it was the diff but they did not believe me or didn't care because it had been lifted, they told me there was no noise from the diff even after I told them to try to spin the front wheels while up on a hoist. Well I am really pissed now and looking for options.
  16. Sep 30, 2010 at 12:05 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Well not many options here, you going have to take the front diff apart. you can replace seal only but by the time you get to it you may as well open the diff up.
    Or find good lawyer:)
  17. Sep 30, 2010 at 12:25 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    This just happened to me so I can tell you first hand like 2 weeks ago. That is the seal you have pictured the CV shaft will actually pull out of that side on the diff housing. Make sure you do not get low on fluid cause if you do you can wear the carrier bearings and you have to replace the carrier all together b/c they dont sell just bearings, and the bearings come pressed in already to the dealership, it will have new spider gears as well though. You can drain the housing and clean the area and you may be able to install a new seal with out having to remove the entire housing from the truck. Then you can put what you took loose back together and insert the CV shaft, re seat it and you should be good to go, but make sure you get the right seal from the dealership as there are two different sizes up there. Mine is an 08 as well so this makes me think the drivers side front diff issues are not just on my Taco. All in all it was not too bad of a job, but we did not re setup the gears and all we just swapped the ring gear to the new carrier checked the pattern and it was all good. Hope that you get this figured. JOE>
  18. Sep 30, 2010 at 12:42 PM
    meafordmike
    Thanks guys
    Joe
    I got a new seal today and plan on replacing it this weekend, I fear when I remove the axle I will find the bearing is shot and then I am screwed.
  19. Sep 30, 2010 at 12:49 PM
    BlueT
    NorthEast
    Here are the master install kit for Tacoma front
    http://eastcoastgearsupply.com/i-133418-toyota-ifs-8-0-clamshell-master-install-kit.html
    It comes with bearings and spacers, you would have to just find somebody to install for you onto the carer. Or look for front IFS used
  20. Oct 1, 2010 at 5:57 PM
    meafordmike
    Going to replace Diff seal tomorrow. I hope when I open it up I don't find the Diff bearing shot. If the bearing is destroyed what are my options?
