Leaking front diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrokenMech, Jan 7, 2017.
  1. Jan 7, 2017 at 2:09 PM
    BrokenMech
    BrokenMech [OP] Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
    Hey guys,
    Have a leak from the front diff where the cv axle goes in. Drivers side. I replaced the seal and cv axle but it still leaks when I drive for a few miles.
    My thought now is the front diff breather might be clogged.
    Any tips or suggestions on how to clean it out?
    Thanks!
  2. Jan 8, 2017 at 8:50 AM
    BrokenMech
    Upstate, NY
    Just an update. Looked at the breather today and it looks like I might have to drop the diff to access it.
    Anyone have a better option?
  3. Jan 8, 2017 at 11:29 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I thought the vents were up inside the engine bay on the driver's side. 2 hoses/tubes that look like they're capped.
    BrokenMech[OP] likes this.
  4. Jan 8, 2017 at 11:46 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Are you out of warranty already?
  5. Jan 8, 2017 at 1:10 PM
    BrokenMech
    Upstate, NY
    No not out of warranty yet.
    Yeah the I located the diff breather. Just not sure what's best way to clean it out.
    Should I just blow some compressed air through it, or disconnect it from the diff and clean it?
    I just installed the ECGS bushing and new cv. That's when the leak started.
  6. Jan 8, 2017 at 1:19 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If its under warranty you should go to the Dealer.
  7. Jan 8, 2017 at 1:44 PM
    BrokenMech
    Upstate, NY
    Yeah I'll probably do that.
    Just wanted to see if there is any tips on cleaning the breathers as a last option.
    shakerhood likes this.
  8. Jan 8, 2017 at 1:50 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Did you put in a new seal? Is it in backwards? Only asking because i know someone who might have done that when installing ecgs bushing:anonymous:.
    Got new seal. Put in properly. No leaks.
    Also, to get to the breather on top of diff is a royal pain in the dick. Almost gave up on it when we swapped my diff not long ago. Luckily @916TacoTruck has the hands of a small girl and was able to get it connected :p
  9. Jan 8, 2017 at 2:23 PM
    BrokenMech
    Upstate, NY
    Yeah put in new seal.
    I thought I had it in right. Which way did you install the seal?
  10. Jan 8, 2017 at 2:31 PM
    tacomgee
    Blake
    NorCal - Ukiah
    Dont recall what it looked like. I just installed the(2nd) new one i got, opposite the way the other came out. No more leaks.
    I'd bet this is your problem considering you didn't do anything else that should cause a leak. Good luck
  11. Jan 8, 2017 at 2:52 PM
    BrokenMech
    Upstate, NY
    I'll try it out. Thx
  12. Jan 8, 2017 at 4:34 PM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    Soft hands too mister!
    Definitely a pain, would highly recommend hiring a midget of some sorts.
