Leaking Front Diff.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FL Forester, Feb 16, 2010.
  1. Feb 16, 2010 at 11:46 AM
    FL Forester
    FL Forester [OP] Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
    Found a spot of oil in the driveway yesterday morning. Looked underneath when I got home from work to see where it was coming from and it looked like it was coming from both sides of the front diff where the CV axles go in. Called my service advisor today and made an appointment for tomorrow morning. When I told him where I though it was leaking from he said that they have had a few in with the same problem. We will see how things go tomorrow.
  2. Feb 16, 2010 at 11:49 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    Sounds like front axle seals.
  3. Feb 18, 2010 at 10:59 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
    Well, they repaced the seal on the drivers side of the front diff. When i looked at the paperwork it is a $9 part. I asked about the other side and they said it wasn't leaking so they couldn't fix it. I go to leave the house this morning and my girlfriend asks me if that spot under my truck is still the one from the other day. Of course it wasn't. I called and I get to take my truck back to them tomorrow.
  4. Feb 18, 2010 at 11:03 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    lol... sorry for your troubles here. If I were you I would probably talk down to the service writer who did half of a job with the heaviest of nice sarcasm.
    hmmm not sure that makes much since after I read it back..... Be a dick in a nice way.
  5. Feb 18, 2010 at 11:06 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    That sucks :(
    Maybe you can politely suggest they owe you an oil change or something
  6. Feb 18, 2010 at 11:07 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    ^ probable the better route to take. I just get mad as hell when people cut corners like this.
  7. Feb 18, 2010 at 11:09 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
    I had them do the oil change since it was a few miles overdue yesterday and they already had the truck. They got rid of their detail department or I would suggest they wash and buff my truck.
  8. Feb 18, 2010 at 11:28 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Out of curiosity how much lift you have ? Do you Have differential drop?
  9. Feb 18, 2010 at 11:37 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
    I have a 2" Ready Lift Leveling Kit spacer in the front. No diff drop
  10. Feb 22, 2010 at 11:36 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
    They replaced the seal on the other side of the diff. They also noticed that the front crank seal was starting to leak so they replaced it. Now I have a leak near the back of the transmission or the transfer case (been too lazy to crawl under and look). You would think that since they spent time under the truck for oil leaks they would have looked under the truck for other problems. The only thing they tried to get me to do was have them change the brake pads for $180 dollars. Said that job needed over $100 in labor which is over an hours time.
  11. Feb 26, 2010 at 7:21 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
    Back from being at the dealership for the 4th time in 2 weeks dealing with the leaking issues. The steering rack is leaking as well as the seal on the transfer case for the front driveshaft. They also noted that there was coolant crust around the weep hole on the water pump. Of course they didn't have the parts in for the steering pump or the tansfer case so I get to go back next week. The service guy did say that the warranty people might want to bring an adjuster to look at everything so I need to wash my truck.
  12. Feb 26, 2010 at 7:56 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    good lord.
  13. Feb 26, 2010 at 8:01 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
    I did run my truck hard for the last 3 months in the woods. It seemed like it rained every week so the roads stayed sloppy. Lots of time in 4wd. I have done worse before and everything held up fine.
  14. Feb 26, 2010 at 8:02 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Are they giving you any hassles for the lift?
  15. Feb 26, 2010 at 8:04 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
    No trouble at all about the lift. There was actually a long travel tacoma there for service as well.
