Leaking gear oil near rear wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluetaco2006, Feb 25, 2020.
  1. Feb 25, 2020 at 12:28 PM
    Bluetaco2006
    Bluetaco2006 [OP] Active Member
    Bob
    Cape Cod
    2006 Tacoma
    Well, the 2006 Tacoma continues to loose the battle against rust. The frame has been replaced. Gear oil starting leaking near the left rear wheel. Thought it was an axle seal.
    No, axle has rusted through. Fix is a new axles and associated parts and labor at ~$6500.
    Discouraging just after our 2003 4 Runner but the dust when the left from lower control arm broke off the frame and the front part of the frame was too rusted to support repair. So had to put the 4Runner down.
    Not sure what to do, I now conclude though that in the northeast you should not try to keep a Toyota longer than 5-10 years.
    PennSilverTaco likes this.
  2. Feb 25, 2020 at 12:35 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I live in Pennsylvania and I've had my 2010 for over a decade (bought new in September 2009); I've never had an issue with anything more than surface rust and my truck still has the original frame!
    If the rest of your truck is in good condition, especially with the new frame, I'd suggest you go somewhere other than the stealership and get a second opinion. You could probably find a wrecked Tacoma with a good rear axle, buy that, and have an independent mechanic do it.
  3. Feb 25, 2020 at 12:41 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Wondering if you could give us some pictures.....never seen anything like what you've described.
  4. Feb 25, 2020 at 12:43 PM
    PennSilverTaco
    Charlie
    X2
    :worthless:
  5. Feb 25, 2020 at 12:47 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    surely it would be cheaper to buy an axle from the SW and have it shipped. I have sold clean rust free housings in CO for $200 ea
    b_r_o, TnShooter and PennSilverTaco like this.
  6. Feb 25, 2020 at 2:52 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Do you mean the axle tube has rusted through and is leaking? Weld it up, or have a patch panel welded onto it.
    Marc70 likes this.
  7. Feb 25, 2020 at 2:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    This, assuming the rest of it is solid enough to do so.
    Other option is a clean unit from a salvage yard.
    $6500? Did that robbery use a gun? Or did it include a running truck?
    b_r_o and whatstcp like this.
  8. Feb 25, 2020 at 3:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    6500??
    Jimmyh and whatstcp like this.
  9. Feb 25, 2020 at 4:45 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @Bluetaco2006 fellow masshole here, North of Boston. :hattip:
    Where are you leaking from exactly? The only leaks I've ever had came from the seal behind the passenger axle.
    I'm shocked that the actual body of the diff is leaking.
    I got over 300k on my 06 and have nothing going on like that.
    Pics, we need pics dood. :annoyed:lol
  10. Feb 25, 2020 at 8:33 PM
    badger
    badger Well-Known Member
    07 SR5
    If you have an axle tube rusted through, the last thing you want to do is try and weld up the hole! With that degree of rust, the whole unit will be weakened, and needs to be junked. Just get a used one from out West, or for 6,500 get a full blown Currie 9 inch Tacoma drop in.
    whatstcp likes this.
  11. Feb 25, 2020 at 9:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Those associated parts must have included a gold bar or two....
    Larzzzz likes this.
  12. Feb 27, 2020 at 3:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    Maybe only 1/2 a bar at today's prices.
    Larzzzz and Jimmyh[QUOTED] like this.
