Leaking Grease from CV Boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DLillest, Mar 21, 2019.
  1. Mar 21, 2019 at 11:07 AM
    #41
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    If you’re concerned about the time between finding the vice grips and boot tear because of the vice grips: take a look at them. There might be some markings which could definitively trace back to the mechanic..Easy street from there.
    Also, get OEM axles if you’re going to replace...
    DLillest[OP] likes this.
  2. Mar 21, 2019 at 11:33 AM
    #42
    DLillest
    DLillest [OP] Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    Noted! Ill keep this in mind, thanks!
    This is definitely good to know. My local Napa has the NEW ones and the REMAN ones. The REMAN ones are actually more expensive but regardless, good to know they are good quality!
    I dont do any wheeling at all, and this may actually be a solution for me to be able to get around until I get the chance to actually repair it!
  3. Mar 21, 2019 at 11:34 AM
    #43
    DLillest
    Quebec, Canada
    Good to know, ill take a look this weekend at the tear as well as the vice grips!
    PzTank[QUOTED] likes this.
  4. Mar 21, 2019 at 1:22 PM
    #44
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    It is not too bad of a job actually. I used the slider hammer method as described in another thread. 3 slides back and it popped out. I was doing this on the ground with a jack stand and used a green metal fence stake to tap the cv back into the diff. 3 whacks, turn, repeat and it'll pop back in.
    DLillest[OP] and b_r_o like this.
  5. Mar 21, 2019 at 3:54 PM
    #45
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Am I alone in thinking it's silly to replace the whole CV because of a little tear in the boot, that is nonsense.... Especially since you caught it in the early stages... I replaced CV boots on my previous '05 Taco and it was simple.... Only "special" tools i had to pick up to do the job was a socket (forget what size) for the axle nut and the crimp tool for the new boot clamps....
  6. Mar 22, 2019 at 4:05 AM
    #46
    DLillest
    Quebec, Canada
    Does it just snap back into place or were you turning it and tapping it until the teeth lined up?
    Did you replace or add grease to the joint when you changed the boot?
    I think the only reason to change it is the same amount of work goes into replacing the boot as replacing the whole thing. And a whole axle can be bought for as little as $30-$60.
    b_r_o likes this.
  7. Mar 22, 2019 at 5:02 AM
    #47
    Captainskidmark
    Northern Illinois
    I cleaned all parts thoroughly and repacked with grease. I don't know how long mine were spewing grease, I just noticed on a hot day there were 2 grease spots on driveway, upon further inspection discovered it was the CV boots. The tears in mine were more significant than what I see in your pics. Even with the tears I had there did not seem to be any dirt evident inside the boot, just a lot of high pressure (real sticky) grease.
    I personally don't like throwing money at something that is not necessarily required. If in fact I did need to replace them, I'd go with genuine Toyota or equivalent quality parts.
    PzTank and DLillest[QUOTED][OP] like this.
  8. Mar 22, 2019 at 6:02 AM
    #48
    DLillest
    Quebec, Canada
    Good point. I only have two small holes a bit bigger than pin size, but it was enough to shoot grease out everywhere.
    It's tough cause the spring whether here is wet, snowy and cold. I just want to get under there and check things out. Doesn't help that I dont have a garage either.
  9. Mar 22, 2019 at 6:55 AM
    #49
    TacomaJack099
    TacomaJack099 Well-Known Member
    Jack
    Orlando Florida
    Blue 2007 Tacoma 2.7 / 5 speed AC 4x4
    about a year ago, while on a road trip about 900 miles from home, saw the grease in the left front wheelwell. I had about 170K miles on the truck, so opted for the replacement axle, and I wanted it done in a day... Checked with two small shops in Winchester Virginia and they passed on the job, because they couldn't get the replacement axle in time. The Toyota dealer said he could get the axle, install and deliver the truck to me about 20 miles outside of town. Took that, but it cost $425. He threw in an oil change for free...
    b_r_o and DLillest[OP] like this.
  10. Mar 22, 2019 at 7:04 AM
    #50
    DLillest
    Quebec, Canada
    Honestly even at $400, that doesn't seem ridiculous. I was expecting upwards of $1000 with the parts and labor.
    For the hell of it, I'll probably get a quote from my dealer when I go in next week to buy the replacement hardware for my rusty door handle bushings.
  11. Mar 22, 2019 at 11:25 AM
    #51
    Larzzzz
    Larry
    MA
  12. Mar 22, 2019 at 11:30 AM
    #52
    ktmrdr
    ktmrdr Well-Known Member
    Clean off the grease and apply black RTV over the holes, assuming the are not large holes. It worked for me.
    whatstcp and DLillest[OP] like this.
  13. Mar 22, 2019 at 12:28 PM
    #53
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I replaced just the boot of the axle while it was still on the truck. Wasn't fun, but it wasn't bad either. Just needed a new boot, grease and a couple straps and was good to go.
  14. Mar 23, 2019 at 8:06 AM
    #54
    DLillest
    Quebec, Canada
    My holes very small. This could be a good solution for me temporarily and to see if it gets worse or not.
    @ktmrdr What type of RTV did you use? I'm seeing a lot of different kinds at my local hardware store.
    Did you remove the knuckle assembly and replace the boot? Or cut the old boot off and install one of those spit boots that you install without removing anything?
  15. Mar 23, 2019 at 8:14 AM
    #55
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Flinging grease from CV's as well torn boots is a normal thing for these trucks.
    I can't stand that we don't have manual hubs and the CV's are basically always moving. I'll probably have to shoot for manual hubs on this thing one day, maybe soon.
  16. Mar 23, 2019 at 8:34 AM
    #56
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I think the reason they got rid of the manual locking hubs down at the wheel is to get rid of the clutter and not have a bunch of greased moving parts that can get covered in dirt and road salt.
  17. Mar 23, 2019 at 6:06 PM
    #57
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Removed the knuckle assembly.
    DLillest[QUOTED][OP] likes this.
  18. May 1, 2019 at 10:07 AM
    #58
    DLillest
    Quebec, Canada
    So I've been real busy in the last month and haven't even driven the truck since I've just been using my daily.
    I went to the dealer last week to get a quote on fixing the torn CV boot and they told me it was practically the same price for a new boot as it was for a new CV axle (parts only).
    • CV axle = $270 CND
    • CV axle boot = $250 CND
    • Labor about $200
    So if I go with a new axle, all in after tax they want around $550. Does this seem reasonable?
    Or am I better off going to an independent shop? Do shops other than the dealer use OEM parts or order aftermarket?
  19. May 1, 2019 at 10:12 AM
    #59
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    https://www.toyota.com/support/contact-us
  20. May 1, 2019 at 4:47 PM
    #60
    TacomaJack099
    Jack
    Orlando Florida
    my cost was $450 back in September of 2018 (or so). I have a comment posted a half page back.
