Leaking Liquid??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gundamzero, Oct 4, 2017.
  1. Oct 4, 2017 at 12:21 AM
    gundamzero
    gundamzero [OP] Well-Known Member
    Ontario, CANADA
    2017 TRD Sport Upgrade DBL CAB
    Hey Guys
    I have a 2017 TRD Sport DCLB
    I came home today from work, turned my truck off and started walking inside, when I noticed my truck was making "popping" noises.
    Then I noticed it was leaking alot of liquid, which looks like water onto the ground. It is coming from the passenger side, near the wheel well.
    I was not using the A/C and the Temp outsidewas about 21C / 70F outside.
    I just had my 8000km check up and the dealership said everything was ok.
    Please excuse the smoke, I was having a cigarette.
    What do you guys think it is??
  2. Oct 4, 2017 at 12:25 AM
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    I think something's wrong with the video you posted..... I can't see it. May be due to me being on my phone. Did you crawl under the truck and take a look? I'd check your coolant level when the engine cools down. Good luck....
  3. Oct 4, 2017 at 1:47 AM
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    You say no AC, defrost or run through a puddle and did not notice? If looks and smells like plain water it is coming from other than your truck.
  4. Oct 4, 2017 at 8:25 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    truck looks like its about to start fire... just sayin... lots of smoke...
  5. Oct 4, 2017 at 8:52 AM
    Tacoma1818
    Tacoma1818 Well-Known Member
    I'm always surprised at the amount of water that flows off of my wife's Sienna. These days, AC is on pretty much constantly in vehicles. Some of them don't even light up the AC switch/control but if you're in defrost mode, it'll be on, causing condensation. And on our Sienna, there's a LOT of it that flows off. My garage floor almost always has a wet spot.
    Stick something under there and check the color and smell. Rub it between your fingers -- is there any viscosity?
    Those 3 attributes will help you determine what kind of liquid it is.
    shakerhood likes this.
  6. Oct 4, 2017 at 9:03 AM
    Fitzpatrick78
    Fitzpatrick78 Well-Known Member
    Robert
    2016 trd sport 4x4 3" lift
    3" front 2" rear leveling kit 285/70/17 on fuel assault
    Based on the picture and lighting the liquid look a bit pink to me. If that’s the case could be coolant, engine coolant or possibly power steering fluid. Watching the video it seems thin so I’d say condensation or coolant leak. Either way I’d check it out further. They may have messed something up.
  7. Oct 4, 2017 at 9:05 AM
    dynamicweight
    dynamicweight Well-Known Member
    Did you recently use your windshield washer sprayer things? I've done that and then been momentarily horrified by the trail of liquid leading to my parking spot only to smack myself on the head when I remember. That does sort of look like the area where the windshield drains to. Perhaps water had been built up in the drain and it was slightly clogged, having unclogged itself when you parked?
    Anyway, if it's just plain water it's nothing to worry about. Check for color/smell to see if it's something else.
  8. Oct 4, 2017 at 9:06 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    first and foremost... take your finger and do the old classic dip and sniff test...
  9. Oct 4, 2017 at 9:09 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    give it a little taste :notsure:
  10. Oct 4, 2017 at 9:11 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Winston?...Marlboro?
    The water sure looks like A/C condensation.
    Tacoma1818 likes this.
  11. Oct 4, 2017 at 9:32 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Is that a Portlandia gif? Is that Carrie?
