Leaking Oil Cooler
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mhelvic, Oct 15, 2017.
  1. Oct 15, 2017 at 10:52 AM
    Mhelvic
    Mhelvic [OP] Active Member
    Crestview, Florida
    1999, PreRunner, XtraCab
    Can someone tell me what this (silver, cylindrical thing) is and what purpose it serves?
    It’s on a 3.4L, on the left side near the oil filter, towards the back of the engine.
    I noticed it looks like it’s leaking. Is it something simple I can change myself or will I have to mess with the internals of the engine?
  2. Oct 15, 2017 at 11:18 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    oil cooler
    devinzz1 likes this.
  3. Oct 15, 2017 at 1:31 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Which cools the oil lol
    Where was it leaking from? Where it threads into the engine block? From the coolant hose?
    You can flush it out with brake clean and put it back on and see if it leaks any more.
  4. Oct 15, 2017 at 2:48 PM
    Mhelvic
    Crestview, Florida
    Yes, it looks like it’s leaking from where the threads are. Thanx, I’ll clean and reinstall to see if it’s still leaking.
  5. Oct 15, 2017 at 2:48 PM
    Mhelvic
    Crestview, Florida
    Thanx
  6. Oct 15, 2017 at 6:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Looks like there is an o-ring that might need replacing @gunny1005 can get one for you really cheap if you can wait for shipping:
    Oh and you should change the thread title (under Thread Tools at the top) to Oil Cooler Leaking at Block or something like that so other people with the problem can find it too!
    BabyBilly, scottalot and gunny1005 like this.
  7. Oct 15, 2017 at 7:32 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    looks like its leaking from higher and dripping down?
    scottalot likes this.
  8. Oct 15, 2017 at 8:00 PM
    Mhelvic
    Crestview, Florida
    Thanx for the info. Will change the title.
  9. Oct 15, 2017 at 8:02 PM
    Mhelvic
    Crestview, Florida
    I’m going to do as Dalandser recommended and clean it up first then change and see if it’s still leaking first.
  10. Oct 15, 2017 at 8:14 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Could be oil from the call cover gaskets pooling around the oil cooler. Clean the area up and see where it's coming from if it's not 100% certain where the leak is coming from. More pics or a video posted to YouTube and linked here could help too!
  11. Oct 16, 2017 at 6:37 AM
    gunny1005
    gunny1005 Well-Known Member
    Phoenix
    there are the gaskets in there
    90301-67004 $3.47
    90210-22001 $3.52
    15785-35010 $0.98
    Dalandser likes this.
  12. Oct 16, 2017 at 9:32 AM
    Mhelvic
    Crestview, Florida
    Excellent, thanx. Deploying for my job today, but will order next week when I return.
  13. Oct 16, 2017 at 10:39 AM
    gunny1005
    Phoenix
    Sounds good
  14. Nov 1, 2017 at 8:10 PM
    Mhelvic
    Crestview, Florida
    Cleaned off the area prior to going out of town. Been back for a few days and used the truck a few times to run errands. The area has remained bone dry.
    Gunny1005, I don’t think I’ll need those oil cooler gaskets just yet.
    Thanks everyone for the suggestions and the help.
  15. Nov 1, 2017 at 10:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah I've noticed that oil from the valve covers may look worse on the block than on the heads maybe because the cast iron seems to soak it in and make it look especially greasy compared to the relatively slicker cast aluminum heads.
  16. Nov 2, 2017 at 5:47 AM
    gunny1005
    Phoenix
    Sounds good, I am glad you don't have a leak..
  17. Nov 2, 2017 at 5:53 AM
    tony2018
    tony2018 Well-Known Member
    You'll have to unbolt it, replace the o-ring behind it, bolt everything back up. torque to spec.
    gunny1005 likes this.
  18. Sep 30, 2019 at 7:29 PM
    paulandsue
    paulandsue New Member
    Paul
    1999 toyota prado vzj95r with the 5vz-fe engine
    Do you have to drain the oil and coolant to replace the cooler seals or can you just undo the bolt and pull the cooler off the block to gain access to the seals to replace them?
  19. Sep 30, 2019 at 8:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah you have to drain it all unless the hoses have enough reach to leave the cooler hooked up.
  20. Sep 30, 2019 at 8:35 PM
    paulandsue
    Paul
    I just read another post on a different site where someone has done several of these without draining any coolant or oil,and had the whole job done in under 30 minutes.
    I think i,m going to try that way.
