Leaking Oil. Need help with identification
Discussion in '1st Gen. Tacomas (1995-2004)' started by MrDunev, Aug 17, 2015.
  1. Aug 17, 2015 at 10:17 AM
    MrDunev
    MrDunev [OP] Well-Known Member
    Los Angeles
    2000 TRD Black Xtra Cab
    2000 Tacoma 3.6 Pre-Runner, TRD, 78k miles.
    So this morning as I walked to my car, I noticed a little puddle of oil under my truck, about the size of a softball. Looked underneath and noticed that the xxxxx (help me fill in the blank) is leaking. Not sure what kind of oil it is, smells like regular engine oil, but I could be wrong. Is it the Transmission pan? I work on motorcycles, but have little experience with cars/trucks.
    Haven't done anything crazy in the truck recently, no off-roading or anything. I did Haul a couple dirtbikes up a some fairly steep hills in 106+ degree weather over the weekend, but thats the only thing I can think of.
    So first, what is the part thats leaking? I am going to check the nuts tonight and make sure they are all snug. Clean it up, and see if the leak continues. If it does, is it pretty easy to replace the old gasket, and add some threebond?
    Thanks for the help
  2. Aug 17, 2015 at 5:30 PM
    MikeZ
    MikeZ Well-Known Member
    Looks like the transmission pan to me. Look on the passenger side as well and see if the the oil cooler lines are possibly leaking as well. Should be 2 of them, out and return.
    It will leak while it is running even at idle usually.
  3. Aug 18, 2015 at 7:26 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Transmission pan. Good time to do the filter and clean fluid.
  4. Aug 18, 2015 at 11:35 AM
    MrDunev
    Los Angeles
    Thanks guys. I checked again today, and there was no puddle over the past 24hrs. I checked the Oil level, while the truck was cold, and it went up to the first twist in the dip stick.
    Sicyota04 likes this.
  5. Aug 18, 2015 at 1:15 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    looks like someone put gasket goop on the pan already (orange stuff) so maybe they reused the old gasket after pulling the pan.
    main thing is oil is going to be black or dark brown and feel slimey and smell like oil and tranny fluid is going to be red or redish brown and smell burnt and feel less slippery then oil.
    if you over filled the tranny, then it may have leaked out the dip stick o-ring until it was below that level
  6. Aug 19, 2015 at 6:56 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
