Leaking Rack & Pinion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Nov 19, 2018.
  1. Dec 2, 2019 at 3:09 AM
    #81
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
  2. Dec 2, 2019 at 11:35 AM
    #82
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Appreciate the info
  3. Feb 9, 2020 at 11:50 AM
    #83
    REDeye jedi
    REDeye jedi Well-Known Member
    Brendan
    Palm Springs
    2001 Tacoma prerunner 3.4l
    quick question sir. And this might seem self-explanatory but I'm going to install the inline filter on the return line for the power steering. What I was wondering is does it need to be high-pressure hydraulic hose or can I run fuel hose since its the return line which is not high pressure. If I'm correct. Only the other end is the high pressure.
  4. Feb 9, 2020 at 1:26 PM
    #84
    Freeheelbillie
    Billie
    Saint Clair, MI
    Good question for someone else.
    That said, I utilized the existing OEM line...since you'll need to shorten it a bit to fit the filter inline no need to replace unless it's in bad shape.
