Leaking rear axle - inner or outer seal??
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingston73, Jul 16, 2012.
  1. Jul 19, 2012 at 11:20 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    The Bearing didn't make any noise when the axle shaft was out and also when things were back together. I took it for a short test drive and things seem good, how long do y'all think it'd take if the seal was still leaking for me to start noticing it?
  2. Jul 19, 2012 at 2:14 PM
    BamaToy1997
    Bill
    Navarre, FL
    depends, if there is a problem it could be so small that you wont notice it for weeks.
  3. Jul 21, 2012 at 5:20 AM
    FINX
    FINX Member
    Austin G.
    Franklin,Tennessee
    '00 PreRunner TRD "Wanna Be"
    Thrush Welded,Deckplate Mod, WAAG Brush Guard,TrailFX Box, Wrangler Authorities
    Mine was doing that for about a week... I got my bearing and my inner seal.
  4. Aug 5, 2012 at 11:27 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    It's been a couple weeks and there is still an oil leak, my inner wheel is shiny and is collecting dirt. I took the drum back off and there is oil right on the axle where it enters the back of the drum, so that means the outer seal is bad? Do you think my brake shoes need replacing even though they are brand new? They have a dark streak on their outer edge, I'm assuming it's oil.
  5. Aug 5, 2012 at 1:47 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Pic? and i am thinking inner seal. does the oil smell like gear oil or brake fluid
  6. Aug 5, 2012 at 2:54 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I don't have any new pics, sorry. how easy is it to screw up porting a new inner seal in? I tried to be as careful as possible but it was the first time I did it, could I have deformed it enough to cause it to instantly start leaking again? um wondering I'd the outer sell is bad?
  7. Aug 5, 2012 at 4:00 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    If it is your outer seal, your in luck (ish):
  8. Aug 5, 2012 at 5:31 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Any ideas for price if I get this done at a shop? I read the write up and replacing a wheel bearing and outer seal is beyond my ability. The more I read the more sure I am that I installed the inner seal correctly so the only thing left would be the bearing and/or outer seal. It's got 184,000 miles so I'm not surprised the bearing is dead.
  9. Aug 5, 2012 at 6:29 PM
    goomba
    Josh
    San Antonio Fl
    Well u can check the bearing when u have the whole axle out and u stand it on the hub. C if the shaft wiggles. sometimes a bad bearing can cause it right away. And try n c if the fluid smells bad. If it does not then it can be ur brake drum cylinder.
  10. Aug 15, 2012 at 7:37 PM
    Drcoffee
    Drcoffee Member
    99 4Runner SR5
  11. Sep 16, 2016 at 3:31 AM
    smokn
    smokn Unsenior Member
    08 DCSB TRD SPORT SR5 4x4
    I hate to revive a well resting thread but I wanted to add my experience. My drivers side started leaking a few months ago. The T4R thread lists a DIY price of close to $700. I called my dealer for a quote just to see because they've been reasonable on parts in the past...$590 OTD for the drivers side. I was pleased with this price to say the least. I have never taken a vehicle into a dealer for work before, but this was a no brainer. My price did not include any brake work, but I can do that later.
    ramonortiz55 likes this.
  12. Sep 16, 2016 at 5:05 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    My import specialist shop cost me $1500 to do all new rear brakes, spring kit, 2 new seals, new emergency brake parts, 2 retainer rings, that previous owner pressed on too far and made the new seals leak. 3 trips total and I had the job done and no more gear oil in my brake drums.
    smokn likes this.
  13. Sep 16, 2016 at 8:35 AM
    smokn
    That really seems like a fair price, all things considered. I think this might be a different conversation if most Joe Schmoe's like me had a press in their garage.
