Leaking snug top!!!
Discussion in 'Tonneau Covers, Caps and Shells' started by Rsanson, Jan 2, 2021.
  1. Jan 2, 2021 at 9:51 PM
    Rsanson
    Rsanson [OP] Well-Known Member
    02 Toyota Tacoma
    None yet
    Hello everyone, I just recently got a used snug top and it’s been working pretty good. Just today it was raining all day, I noticed there is not a whole lot but definitely some water in the bed of the truck. Is this a simple repair? Or should I try to sell the shell and just buy a brand new one?
  2. Jan 2, 2021 at 10:00 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Rsanson[OP] likes this.
  3. Jan 2, 2021 at 10:23 PM
    Rsanson
    02 Toyota Tacoma
    None yet
    Thank you. I have a repair scheduled for next Sunday for no charge. He is just going to re seal the windows
  4. Jan 14, 2021 at 4:52 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    If the window re-seal doesn't work (or doesn't address all the leakage), the way I chased down small leaks in my cap was to clean the bed out and then throw a handful of flour down in the bed, batten down the hatches, and then go nuts with a garden hose for a while. After giving it a few minutes to drip, looking inside showed exactly where the water was trailing from - there were obvious tracks in the fine powder scattered all over the place. In my case it happened to be the bottom corners of the rear door, and cleanup is easy with the garden hose you already have in your hand.
    Something else to consider - I am not familiar with the beds of the 1st gens, but on 2nd gens at least, the top of the front of the bed is lower than the sides, especially with the factory covers in place, and a typical gasket between the shell and the bed can't quite make a good seal, particularly in the front corners. Several companies make bed gap fillers of various heights for different models of truck.
