leaking some sort of fluid that stinks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blake28104, Dec 13, 2011.
  1. Dec 13, 2011 at 5:07 PM
    Blake28104
    Blake28104 [OP] Active Member
    Blake
    Phenix City Alabama
    09 Prerunner SR5 W/ 3" Toytec Lift
    Areo Turbine Muffler 4" Roll SS Tips at 45 3'' Toytec Lift Toytec Rear 2" AAL's 20" KMC Monsters Nitto Terra Grapplers 33" 275-60-20 6000K Fog 6000K RETROFIT Headlight HIDs BY: Morimoto LED Led Corner Lights LED Tag Lights Flat Tinted Tag Cover Memphis PR1000.1 Amp 2 Rockford Fosgate P3s Scanguage11
    the other day i noticedthis strange smell . the smell is coming from the side where the break booster is . its not burning motor oil . so i got under my taco and it only has 50k miles. there is something leaking above onto the frame and some how getting onto my catalytic converter and burning and and smells like somthing i never have and it stinks like hell . any idea what it might be i think it might be coming from a leaking line from that spot ?
  2. Dec 13, 2011 at 5:08 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Still under warranty? Take it to the dealer. It may be you blinker fluid leaking though.
  3. Dec 13, 2011 at 5:11 PM
    Blake28104
    Blake
    Phenix City Alabama
    ha yeah i thought it was my blinker fluid . well im sure the dealer will try to charge me . saying my lift is what is causing it
  4. Dec 13, 2011 at 5:13 PM
    Blake28104
    Blake
    Phenix City Alabama
    its not coolant its a fluid maybe power steering or brake fluid maybe thats what area its coming from or maybe from a line from the two . idk
  5. Dec 13, 2011 at 5:16 PM
    Warhorseforever
    Will
    Sand Lapper
    Lol +1 for sense of humor. Are you sure it's leaking on the cat's and not the headers? Maybe something with the power steering. I'd start by checking all of my fluids. Do you have tow package? Maybe something is leaking from the coolant lines for your trans.
  6. Dec 13, 2011 at 5:21 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Only fluid reservoirs over there IIRC is brake and possibly clutch.
    I suppose it's possible thought very unlikely that somehow gear oil is backing up the breather tubes right there and some how dripping on your cat. That'd be pretty odd though.
    There should only be AC heater fuel brake and vacuum lines around there I think. Maybe tranny cooler lines as said.
  7. Dec 13, 2011 at 5:25 PM
    Blake28104
    Blake
    Phenix City Alabama
    yeah its on the cats i can see it on there and its not getting on the headers . not clue how the hell its on the cats but its burning on there becuase i got under the truck to see if i can see where its coming from and yeah i got the tow package on my truck and my best guess is that it its coming from the lines running somewhere under where the drivers side dripping onto the fram and then however its getting on to the cat converter but its not on the cat heat sheild. seems stange to me :confused:
  8. Dec 13, 2011 at 5:35 PM
    Warhorseforever
    Will
    Sand Lapper
    Next best course of action in the morning would to check all fluids on level ground. If all checks out then start it up and look for leaks if you still don't find anything let it run for a few minutes to let everything warm up the look again.
  9. Dec 13, 2011 at 5:42 PM
    hogeyphenogey
    hogeyphenogey Rotted frame = New Truck!
    Dave
    Chicopee, MA
    2015 TRD Off Road Crew Cab in White
    RokBloks mudguards, tonneau cover, cut my old LB bed mat to fit my SB, weathertech mats, RedLine hood struts, LED interior and plate lamps, child seat in the rear (my kid is the best mod so far!), center console light and "restaurant" organizer, floor-mount phone cradle, red grille emblem, red tow hook.
    Could you have driven through something that splashed up on there and smells? Do you see any leaks? Drops on the garage floor? If so, what color is it?
  10. Dec 13, 2011 at 6:02 PM
    takao96753
    takao96753 Member
    mike
    KIHEI
    2010 Reg Cab 4wd
    The stinkiest fluid is gear oil.
  11. Dec 13, 2011 at 6:47 PM
    Blake28104
    Blake
    Phenix City Alabama
    idk it not thick like gear oil unless its coming from the steering ? its kinda yellow is from what i see. but most is like soaked into the metal like a slow leek not enough to drip . but i will watch the fluid and see. i think ill call the dealer tomorrow and see what they think or how they can rip me off !
  12. Dec 13, 2011 at 6:49 PM
    Blake28104
    Blake
    Phenix City Alabama
    Its not thick like grease or anything its somthing with a thin consitancy
  13. Dec 13, 2011 at 6:52 PM
    Blake28104
    Blake
    Phenix City Alabama
    also its kinda oilly right under the break booster but i dont any leaking from the break fluid or lines
  14. Dec 13, 2011 at 6:53 PM
    Blake28104
    Blake
    Phenix City Alabama
    my coolant is pink its nit the coolant leaking
  15. Dec 13, 2011 at 7:04 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Until reading past the headline, i thought it was more of a personal problem that a '2nd gen' issue...
  16. Dec 13, 2011 at 7:41 PM
    Blake28104
    Blake
    Phenix City Alabama
    well i was wondering if anyone else ( Gen 2 ) was having the same problem or had the same issue but thank you for your input though ! :D
  17. Dec 13, 2011 at 9:03 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    Only thing I can think of that's that color would be brake fluid so maybe brake master or clutch slave?? Tranny fluid isn't yellow either. Have you checked all the fluid levels?
  18. Dec 13, 2011 at 9:09 PM
    joes06tacoma
    Joe
    Central Coast, CA
    A "friend" put limburger cheese on my catalytic convertor when we were in high school. You want to talk about stink?:rolleyes: It was almost liquid by the time I found it.
    If you have a fluid leak at the brake booster, then it's probably brake fluid from a leaking master cylinder. Not sure why that would stink.
  19. Dec 13, 2011 at 9:15 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    gear oil smells like shit imo maybe thats it?
  20. Dec 13, 2011 at 9:23 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    gear oil burning off smells really weird
    Never smelled that until I tempered a tool in a bath of gear oil... it's bizzarre
    I'd soak the whole fucking thing down with brake clean and see if it comes back
