Leaking Sunroof/Moonroof
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Greensummits, Mar 25, 2020.
  1. Sep 6, 2023 at 1:03 PM
    #121
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Got to clean those drain holes. They get spiders/debris in them over time. It sucks super hard when it happens (happened in my forester years ago) It’s just the way it is.
  2. Sep 6, 2023 at 2:48 PM
    #122
    USMCGRUNT
    USMCGRUNT Well-Known Member
    Philadelphia
    2020 TRD Pro - Mag Gray
    I am sorry to hear that. I am definitely not ready for that to happen...I knew the first time I saw it that it was a terrible design. Essentially water is coming into your vehicle and going through drain rails. The only thing separating the drains rails from the interior of your vehicle is a headliner.
    Like others have said, I am trying to stay up on cleaning those drains out. Still not an excuse for that design IMO.
  3. Sep 6, 2023 at 2:57 PM
    #123
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I check my channels to make sure they’re clean. Haven’t had any water drip in the truck but I have noticed that they have been damp. If it rains really hard no leaks yet seems to be draining. I’m really glad I got my sunroof. I use it all the time. I also go through automatic car washes with no issues.
  4. Sep 6, 2023 at 3:00 PM
    #124
    GatorBodine
    GatorBodine Well-Known Member
    Jay
    23' 4 cyl.
    Where and which drains handle the sunroof water, so I can keeps tabs on them?
  5. Sep 6, 2023 at 3:26 PM
    #125
    USMCGRUNT
    Philadelphia
    Dcubed69 and GatorBodine[QUOTED] like this.
  6. Sep 6, 2023 at 3:42 PM
    #126
    2023TRDOffroad
    2023TRDOffroad Well-Known Member
    California
    ‘23 DCSB TRD Off-Road 4x4
    My 02 Land Cruiser had the same issue. My understanding is that leaking is normal, it’s expected, hence why drain lines are installed with a sunroof or moonroof. When my sunroof motor crapped out, I fixed the leaking with some RTV gasket maker and sealed it up for good. Fast forward to my switch to my 23 Tacoma, no sunroof was actually a selling point for me for the Off-road vs the Pro, as I bought this truck wanting to keep it forever, and I can speak from experience when I know sun roofs are just constantly leaking. You can’t blame Toyota, it’s part of the design of any sunroof. A gigantic hole in your roof with a rubber seal around it to seal it will always allow some water in, the question is are your drains up to the required workload for that rain storm (or that car wash).
  7. Sep 6, 2023 at 3:47 PM
    #127
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Mine is a 2016 and leaked for about a year and a half and I went on an all out mission to figure out what was going on, especially since it damaged the sunroof motor and would drip inside the cab on turns and hills, most of all I couldn't find the "closed" position on the sunroof any more which made it really leak.
    TLDR: Replacing the rubber gasket that goes around the glass. About $75 and 90 minutes of work.
    Long story:
    Water started dripping on me from the roof console. The one-touch open/close on the sunroof stopped working, then it started making a whining sound as the sunroof opened and close. And eventually there was no more "closed" position. It would go straight from sliding close to popping into the vent position.
    I got a USB endoscope camera and setup the garden hose to run a sheet of water over the sunroof. It leaked so much in the corners they weren't drops but a constant stream. The drains (never cleaned and I park under a tree) had no problems moving the water. They leaked particularly bad in the front corners. The sunroof track system has a design problem (I dropped the headliner to see at one point) where if water drips on the 2 piece cover that hides the toothed belt, it will get into the belt system and drain into the motor and that's what was happening to me. I initially siliconed all the seams around that part of the belt system but then the water ran across the top which seemed even worse to me. I 3d printed some caps and diverters that I glued to the tops of the belt covers. Those moved the water into the gutters and out the drains. That MOSTLY fixed the problem but not fully.
    It wasn't until I replaced the gasket that I realized that although the original gasket was making contact with the sheetmetal, there wasn't enough force to make a firm seal. To gauge, with the original gasket I could easily slide a business card between the rubber and the metal, but with the new gasket I couldn't without enough force to bend the card. Now problem is solved. There's no water leaking even with a direct stream of water from the garden hose at a single point on the seal.
    deusxanime and bulalo like this.
  8. Aug 22, 2024 at 6:36 PM
    #128
    Egtaco16
    Egtaco16 Well-Known Member
    Erick
    23' Trd Offroad
    Was yours a slight drip on the backside? And if so, what have you done or what has anyone else told you about it. Totally normal or abnormal. I got the same issue with my 23' tacoma and 50/50 are saying its normal and abnormal
  9. Aug 22, 2024 at 6:39 PM
    #129
    Egtaco16
    Erick
    23' Trd Offroad
    A little late but im having similar issue with my 23 offroad, drips right above the catch tray. What have else have you noticed after noticing this issue, no seepage on headliner or anything?
  10. Aug 22, 2024 at 6:44 PM
    #130
    USMCGRUNT
    Philadelphia
    I just rode it out and never had any issues. It was definitely a poor design, but thankfully it never leaked inside the cabin. I did get one of these cheap pipe cleaners and cleaned it out a couple of times...There are videos on Youtube how to do it. https://www.amazon.com/gp/product/B08MQCNTQY?ie=UTF8
    I sold mine in December and my 24' Pro was loaded on the ship on August 18th. I am hoping to have it soon.
    Good luck!
    deusxanime likes this.
  11. Aug 22, 2024 at 6:46 PM
    #131
    Egtaco16
    Erick
    23' Trd Offroad
    Congratz in the new Taco! In the time of your ownership it has always dripped like that in the back seals? Str8 to the catch tray id assume
  12. Aug 22, 2024 at 6:49 PM
    #132
    Egtaco16
    Erick
    23' Trd Offroad
    Im crossing my fingers i dont come across it leaking into the cabin. Its more so small drips going into that tray but it was not pouring rain like crazy. Had I not inspected it though i would not have seen it. In my 8 months of ownership i just realized it now, so all the other times it rained it probably did the exact same. Im going to have to check the surrounding headliner areas if its moist and also check the drains on it.
  13. Aug 22, 2024 at 6:54 PM
    #133
    USMCGRUNT
    Philadelphia
    I caught mine the first day I purchased it because it was raining. It stayed at the dealership for an extra week and no one could figure it out. What they finally came back with is, "it is designed this way."
    I never had any issues with it coming in the cabin, but I have read that people who parked on large inclines during heavy storms did get water inside. You just have to make sure those drain tubes are cleaned and clear. You get leaves and everything else that builds up in those tubes and then the water can't empty from the bottom. There are several videos on Youtube that show exactly how far down those drain tubes go.
  14. Aug 22, 2024 at 7:45 PM
    #134
    Egtaco16
    Erick
    23' Trd Offroad
    Will check it first thing tomorrow. I have contacted the dealer service manager and Im anticipating for him to also claim that it is designed that way but I will wait for his response
  15. Aug 23, 2024 at 1:30 PM
    #135
    hr206
    Western Washington
    I dealt with a leaking sunroof for about a year that eventually burned out the sunroof motor. I bought a usb camera on the end of a semi flexible cable I can connect to my phone so I could find it.
    My truck is parked outside 100% of the time under a tree. I live in the PNW so it rains a ton. This is what I can say.
    1. If you put the end of your garden hose (without a nozzle) on your roof and turn in on fully so that most of the water is running over your sunroof, you should have ZERO leakage.
    2. The sunroof is not watertight but it's also not designed to leak meaningful amounts of water. It should be more or less waterproof in heavy rain.
    3. The way that the sunroof is designed, if you have leakage in the front corners of the windshield, it is highly likely to drain directly into the channels that carry the belt that opens and closes the sunroof. Those channels drain directly into your sunroof motor.
    After many attempts including completely removing the headliner, turns out that replacing the rubber gasket around the sunroof glass fixed it more me. My rubber gasket was in good shape and making good contact with the metal. I slid a piece of heavy paper between the roof and the rubber seal and slid it around and found the front corners, while making 100% contact, was just a bit looser than everywhere else. I bought a new one <$100 online and was easy to do. The circuit board on my motor was toast. A Tacoma specific sunroof motor is almost $500. But all the Toyota motors are very interchangeable between any recent Toyota. I'm sporting a Rav4 motor from eBay for $50 and it works just fine.
  16. Sep 8, 2024 at 5:00 PM
    #136
    topochico23
    topochico23 Well-Known Member
    2022 DCSB SR5 V6 4x4
    We also have a 2024 Highlander XLE with the smaller sunroof. It leaks in the car wash worse than any GM, Ford or Chrysler I had growing up. Needless to say my Subarus and Hondas never had this problem.
    sounds like replacing the gasket myself might help. After that I might pull the fuse and kill the sunroof. Then vinyl wrap the roof and hope that this brand new Toyota leaks less water than Toyota corporate itself, which appears to be a sinking ship.
  17. Sep 11, 2024 at 1:23 PM
    #137
    Charlie Marlow
    Charlie Marlow Well-Known Member
    Georgia
    19 TRD OR
    Sorry for a very late reply. It's a slight drip on the backside, but I haven't done anything about it as I only saw it with a lot of water and every sunroof I've ever had leaked a little. The panoramic sunroof in my 2017 F-150 I traded for the Tacoma leaked an alarming amount of water on both sides at the midway point, but it was all caught by the drainage tray and never wet the headliner.
  18. Apr 3, 2025 at 12:31 PM
    #138
    LDB68
    LDB68 New Member
    Just got a brand new Gen 4 2025 Tacoma TRD sport Premium. a few days after (430Km)I picked the truck at the Dealer there was some rain and my Head liner was soaked. Took the truck back to the dealer and they could not find where water was coming from. After another 5 days it rained again and I kept myself busy reseaarching on the web possibilities for the problem and found a few videos on clogged Moonroof drains.
    Tried to clean with some weed waker line but it only was able to push in the hole about 4 inches. Took it back to the dealer and explained what was happening and even got videos of the water pooling on the driver side and not moving down the hole, instead was driving inside the cab.
    The dealer opened the column liner and the head liner and found that when the truck was build (in Mexico) the plastic hose got pinched and created a kink so water was not passing. They tried to fix the kink with no success and it is still not giving water passage.
    They ordered a new hose and it will be all covered by warranty, but looks like it might take between two weeks and two months to get that replaced and fixed, meanwhile I will be driving a submarine during spring break(rain season)
    Very frustrating considering I have been driving different Toyota models with moonroofs for the last 20 years and never had any issues with that. And the worst part is that I contacted Toyota Canada costumer service and they told me on the Phone that the dealer is the one that needs to take care of it, and they can do nothing.
  19. Apr 3, 2025 at 1:44 PM
    #139
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You've revived a very old thread on the 3rd gen forum
    you say you have a 4th gen
    shakerhood likes this.
  20. Apr 4, 2025 at 8:19 AM
    #140
    LDB68
    LDB68 New Member
    Yes, my is a 2025 (4th Gen) TRD Tacoma Sport Premium.
