Leaking transmission fluid in 4-drive, not in 5th overdrive.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mttchw8181, May 2, 2023.
  1. May 2, 2023 at 2:48 PM
    Mttchw8181
    Mttchw8181 [OP] Member
    A bit backstory, 2008 4.0 auto, 230k truck has been shuddering sometimes when 35-50 mph at low throttle (fast pace it doesn't do it), I assume torque converter lockup too early is the cause. When I run it in 4- gear drive over 50 mph it blows tranny fluid , when in overdrive dealing with the shudder it is fine. Any ideas? Is it related to torque converter or possibly 2 issues, like high fluid level & malfunctioning converter. What can I do. any ideas?
  2. May 2, 2023 at 3:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Where is it leaking from?
    I have not idea why it wouldn’t leak in 5th gear, but does in all other gears?
  3. May 2, 2023 at 3:46 PM
    Mttchw8181
    Doesn't seem to do it in 5th, only when 4-gear drive & after about 5 miles driving going 50-55+ mph. Not towing anything just the truck itself.
  4. May 2, 2023 at 6:14 PM
    Mttchw8181
    I have no idea where from, only that transmission fluid coated the bottom of the tranny, the multiple times I experienced it.
