Leaking Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwilliams81, Jul 31, 2022.
  1. Jul 31, 2022 at 12:58 PM
    dwilliams81
    dwilliams81 [OP] Well-Known Member
    2012 2.7L Tacoma 4x4
    2012 2.7L 5 speed manual 53,000 miles. I just bought the truck and I’ve been changing all the fluids as I’m not sure what the previous owner done. I drained and filled the manual transmission with redline mt90 but I did not use new crush washers. I crawled up under the truck and it is leaking at the fill plug not the drain. Should I open the drain and put a new crush washer in? I’m not sure what else would be causing the leak other than that. The drain on the passenger side is dry but the fill plug was wet and under it was wet. Thanks.
  2. Jul 31, 2022 at 1:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It certainly won’t hurt to try a new crush washer.
    That’s what I’d do.
    I try to use a new one on the drain plugs. I usually reuse the fill washer.
  3. Jul 31, 2022 at 1:10 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Did you torque the plug to spec? If you did or didn't you could try giving it a little extra to see if that stops the leak. If that doesn't work, a new crush washer is needed. Capture what fluid you can in a clean pan and replace (always) the crush washer.
  4. Jul 31, 2022 at 3:04 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You can also use Teflon tape. I use it regularly and have for years.
    I would recommend against going very tight. Remember, you are screwing into aluminum. Just snug and the Teflon tape will make the fit a little more snug for some peace of mind.
  5. Jul 31, 2022 at 3:10 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i would just order a new crush washer but teflon tape should work fine. like winkel said, you don't want to overtorque it. doubt it's a serious leak so you should be fine to wait until you can get it.
  6. Jul 31, 2022 at 7:24 PM
    dwilliams81
    Could it be clogged vent as when I released the fill plug it sounded kinda like a vacuum when it was released. Where would it be located and how to clean it.
