Leaking up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, May 13, 2025.
  1. May 13, 2025 at 3:57 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Ok....so random thing....
    My passenger side floor board is wet as if absolutely soaking wet as in I poured a 20 ounce (or more bottle of water on it).
    Coolant level is at 100%
    It only happens when it's a crazy huge downpour.
    The carpet on the vertical surface under the dash by the fan and evaporator is dry. The carpet on the floor of the rear seat is dry. It is simply the spot where your feet would be when sitting in the passenger seat and it is 100% soaked. Any help would be appreciated.
    This is the second time it has happened. The first time I just figured one of my kids must have spilled a drink or the window was cracked during a downpour and I didn't realize it.
  2. May 13, 2025 at 4:29 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    In the past, with another truck of mine, I had to run hose water on the exterior while I searched for where the leak was coming from. There were rust areas near the firewall corner that was allowing water in. I did this on a dry day and used a good flashlight to lie on back and look up. My guess is it's still coming down from somewhere. If you dry out the carpet, then run the hose, you may be able to figure out where is getting wet first while monitoring it, to get a feel on the direction of water intrusion.
    Gunshot-6A likes this.
  3. May 13, 2025 at 4:42 PM
    Bishop84
    Bishop84 Well-Known Member
    Leaking windshield is a very common issue.
  4. May 13, 2025 at 4:45 PM
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    I'd check that black plastic cowl portion between the bottom windshield and hood.
    Gunshot-6A and Sterling_vH111 like this.
  5. May 13, 2025 at 4:47 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. May 14, 2025 at 9:54 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There was a TSB for the Cowl Leaks on the 2005 Tacoma but the 2006 also suffered from this issue to a smaller extent. See below which has a link to the TSB. The TSB explains how to troubleshoot and repair any leaks that are found.
    Read the TSB Linked: https://www.tacomaworld.com/attachments/bo00405r-05-leak-pdf.1051900/
