Leaking upper radiator hose.
Discussion in '1st Gen. Tacomas (1995-2004)' started by HillBilli, Feb 5, 2024.
  1. Feb 5, 2024 at 10:04 PM
    HillBilli
    HillBilli [OP] Active Member
    Yea the specs were in Chinese lol
    not joking.
  2. Feb 5, 2024 at 10:09 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    It looks like on the radiator end he already has a constant tension clamp?
    The yellow crust looks crazy. I hope someone knows what's up there.
    FYI for the small hoses to the coolant overfill tank, heater hoses, etc, this Amazon pack is great. Oddly the little wire spring clamps Toyota uses are unreliable, caused me a leak on a new hose that I fixed with these.
    https://www.amazon.com/gp/product/B07SVXM3JQ
  3. Feb 7, 2024 at 11:03 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    That's right. Replace BOTH hoses, and clamps, with OEM. And while the hoses are off, clean the radiator hose connections with some solvent, dry them, and then use some emery cloth to smooth out the mounting surfaces before installing the hoses. Make sure the hoses are NOT a loose fit when you install them.
  4. Feb 7, 2024 at 2:34 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    I think the Yuk is from mixing antifreeze
