Leaky BJ's
Discussion in 'Suspension' started by Bobbb, May 28, 2012.
  1. May 28, 2012 at 2:05 PM
    Bobbb
    Bobbb [OP] "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    After reading through a gazillion threads, I haven't quite found this answer yet so here goes-
    Gawked under the front end today and noticed what looked like a greasy spot inside one of the wheels. Grabbed the creeper and, sure enough, it was grease. Followed it up and found that my upper ball joint was leaking. Checked the other side and sure as shat--same thing. Swell. No other leaks or issues to be found anywhere except the UBJ's and the boots appear to be intact.
    '11 SR5 4x4 with 12K miles. Swapped for 5100's at 1.75 approx 6K miles ago with stock springs. Everything else is still stock as well. I have been off-road a few times since the swap, but articulation hasn't been overly extreme. I do get slight wandering on the highway with 265/70R17s and rubbing on the splash guard, but no contact evidence anywhere else. No hard impacts to either side since last aligned following rear spring TSB install.
    Could this be the result of a bad alignment? Or do I just need to bite the weenie and get new UCAs? Perhaps something else? Thanks in advance for any suggestions.
  2. May 28, 2012 at 2:08 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    hehehh he said....BJ....hehehhhh
  3. May 28, 2012 at 2:17 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    that's what I was thinking when I saw this thread...lol
  4. May 28, 2012 at 2:19 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Gotta get 'em in the store before you can sell them anything! :D
  5. May 28, 2012 at 2:23 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    still under warranty?
  6. May 28, 2012 at 2:24 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Tell her to swallow.
  7. May 28, 2012 at 2:30 PM
    theredofshaw
    that won't help with leaky BJ's either...might make it worse and hurt a little....
  8. May 28, 2012 at 2:34 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Still under warranty, but I'm betting they'll say no because of the billies install. Just guessing at this point.
  9. May 28, 2012 at 2:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    wut
  10. May 28, 2012 at 2:42 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    they sell billies at the dealer. i dont see why they wont cover it
  11. May 28, 2012 at 2:48 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Closed for the holiday today so I have to wait until tomorrow to find out, but I will definitely be asking. Just hoping someone else might have seen this issue before so I know what I'm up against.
  12. May 28, 2012 at 4:05 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Poss tear in the bushing? Jack it up so the tire is off the ground and the UCA is flexed, if theres a small tear or hole you'll see grease coming out. My Camburg UCA's do it cause theyre the bj ones but theyre also greasable!
  13. May 28, 2012 at 7:06 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Jacked it up earlier and took a look-see, but didn't find anything. That was with the tires in my way so I'm planning to yank them tomorrow so I can get a better look. Can't imagine them both tearing with so few miles, but I'll see what I can find. Thanks!
  14. May 29, 2012 at 12:56 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Yanked both wheels to have a better look and couldn't find anything obvious. Just sked an appt with the stealership so I guess we'll see what they come up with. Even they said they haven't heard of this before with the stock stuff so I guess that makes me the lucky one. :(
