Leaky Diff. 2007 Tacoma 2wd
Discussion in 'New Members' started by OhNoJoe_07_Taco, Jun 27, 2020.
  1. Jun 27, 2020 at 7:22 PM
    OhNoJoe_07_Taco
    OhNoJoe_07_Taco [OP] New Member
    Joe
    Reading, PA
    2007 Tacoma 2WD 2.7L 4-cyl
    Stock. Lots of mending.
    Leaf spring was wet with diff fluid, but not the brake hub... I narrowed it down to a leak that is hidden directly under the spring aligner that is welded to the differential case (OEM). I just cut the bottom of the spring aligner out today and cleaned up all the rust. From the inside of the case when I have the passenger side axle removed (aside from the heat marks from the factory welding) there was a faint brown rust spot that I spotted with an extendable mirror and flashlight. I was able to get a tiny probe to poke through it without much force at all. This tiny hole caused my entire leaf spring to become saturated in diff fluid. It was NOT (I repeat) was NOT coming from the seal, although I will be replacing that due to the extensive work I currently have under weigh on the diff case. My plan is to braze the hole and re-fabricate the bottom of the alignment plate from a piece of 1/4" mild steel. I'll chamfer the edges of the fabricated plate and weld it back in place. I have all the tools, so why not?!?
    Interested in pictures? If 4 people ask I'll grab the camera and post for you to see. I bought a harbor freight needle gun today to clean all the flakey rust off the diff case. Some whopping 1/4" chunks came off! I think it'll be fine...
    EDIT: I'll be posting videos of the restoration. You can find them here.
    https://youtu.be/VmbAO-GkVzY
    https://youtu.be/f0Pf68aVEk0
    Anyone else got this going on? I'm so lucky Toyota left all the other rusty goodies for me to fix after they replaced the frame!! =D
  2. Jun 27, 2020 at 7:25 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
  3. Jun 27, 2020 at 7:39 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  4. Jun 27, 2020 at 9:54 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    OhNoJoe_07_Taco[OP] and tcjacado like this.
  5. Jun 27, 2020 at 9:57 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I’m down for pics. Let’s see it.
    OhNoJoe_07_Taco[OP] likes this.
  6. Jun 28, 2020 at 4:02 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Thank you for the vid!
  7. Jun 30, 2020 at 3:21 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
