leaky diff
Discussion in 'Technical Chat' started by sr5boy, Jul 22, 2009.
  1. Jul 22, 2009 at 5:15 PM
    sr5boy
    sr5boy [OP] Well-Known Member
    tallahassee florida
    06 tacoma 4x4
    demudflapped, debadged, relocated the 7-pin, 3'' fatbobs garage lift in front
    I took the spare tire out of my truck the other day and noticed that my rear diff was oily. There was dirt and gime on the diff plate and fresh oil puddled/hanging on the bottom of the diff. I asked my brother why and he said that the oil must be getting really hot and is pushing out of the seals. I drive 40 highway miles a day and have 285/75/r16. Do any of you guys have answer for this?
  2. Jul 22, 2009 at 5:42 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Those plugs should be torqued to 36 lbs.
  3. Jul 22, 2009 at 5:51 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Ask your brother how the oil is pushed past the seal on a vented diff.
    Get a light and get under there and find out where it is coming from
    Drain plug
    third member gasket
    Pinion seal
    Do you have a locker?
    If it is not obvious get some parts/brake cleaner and a rag and clean it up and then check again after a day or so.
  4. Jul 23, 2009 at 2:47 AM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 Access Cab 4x4, 17 TRD Sport 6 MT
    Leer 100R
    Thanks for the info guys, just noticed a small leak on mine. Time to get the torque wrench out.
  5. Jul 25, 2009 at 1:06 PM
    MGRS
    MGRS Well-Known Member
    08 6spd TRD 4x4
    Mine started leaking from the drain plug yesterday.
