Leaky engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinchetaco, Oct 29, 2012.
  1. Oct 29, 2012 at 9:01 AM
    pinchetaco
    pinchetaco [OP] Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35x12.50x18 Red Letter Generals, ProComp Wheels, Debadged, Black Headlight mod, Dome Light Mod, Trailer Plug Relocated
    So my seeping timing cover leak has turned into something a little more. It is now leaving spots in the driveway. My question is, has anyone done this before and is there a write up for it? I had searched online but i didn't happen to find anything. What is needed to do it and how difficult is it? Any advice will help and any suggestions would help. Oh and btw I'm way beyond the warranty.
  2. Oct 29, 2012 at 12:13 PM
    Atreyus
    Atreyus WRATH OF ATREYU
    William
    San Gabriel, CA
    2010 Prerunner SR5 TRD SPORT
    5k Headlights HID's DDM, 3k fog HID's DDM, Interior LEDs, License plate LED, Tailgate mod
    If it's the valve cover gaskets and if it's anything like my 1997 4runner it shouldn't be too hard.
  3. Oct 29, 2012 at 12:16 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    I couldn't tell from your info if your truck is a 4 or 6 cylinder. big difference in timing covers, that's why I ask.
  4. Oct 29, 2012 at 12:29 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    it's an 8-10 hour job to replace <$100 in parts...
    literally have to tear the top of the engine down and pull most everything off the front of the engine...
    i have the issue to, but i plan on having my buddy at toyota do the work for me...it's a 8-10 hour job for him, so outside of the shop, i'd expect more than that.
  5. Oct 29, 2012 at 2:28 PM
    BamaToy1997
    Bill
    Navarre, FL
    Depends on the engine as I mentioned. Labor time for a V6 according to Mitchell is 12.2 hours, which yes, can be done in 10. The 4 cylinder 4X4 however has a labor time of 19.0 hours, and is quite extensive as removal of the oil pan (or at least lifting of motor off mounts and lowering oil pan enough to access oil pickup) takes a bit of work and time. If you are experienced enough you can remove and reinstall the timing cover of the 4cyl without replacing the head gasket.
  6. Oct 29, 2012 at 2:34 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    :eek:
  7. Oct 29, 2012 at 2:37 PM
    BamaToy1997
    Bill
    Navarre, FL
    Yeah. The actual procedure by Toyota calls for removal of the engine to replace the timing cover.
  8. Oct 29, 2012 at 4:16 PM
    pinchetaco
    Winston Salem, NC
    Mine is a 6 cylinder. Yea I starting to get annoyed with the drip and I'm thinking its gonna be a pain to remove the cover and fix it.
  9. Oct 29, 2012 at 4:17 PM
    pinchetaco
    Winston Salem, NC
    What kind of parts are needed for the job?
  10. Oct 30, 2012 at 6:13 AM
    BamaToy1997
    Bill
    Navarre, FL
    Before you tear into the engine, lets check a few things. Timing cover seals are a rare leak. Are you 100% sure it is not a valve cover leak, or a front seal leak that is dripping down? Or an oil pan leak?
    The reason I am asking is that even the 4.0 V6 is pretty complicated to remove the timing cover. No need for excessive work. I would suggest cleaning the front and bottom of the engine with a good degreaser, and inspect for the exact location of the leak before you tear into this. I will be more than happy to help you with information on the job, I just want to be sure that you are looking at the actual timing cover gasket leaking.
  11. Oct 30, 2012 at 7:02 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    05-08 tacomas (mainly the earlier productions) have a tsb out for the timing cover seal actually, so it's very common with our year
    ask any toyota tech, they see it a lot with our years.
    edit:
    T-SB-0326-08 OCT 08 Engine Mechanical - Oil Leak from Front Timing Cover
    you can see in the diagram in the pdf^ where the leak most commonly is...
    i know mine is about there as well...it's not terrible right now, but i'm waiting for my buddy to have some days off to take it into the shop to work on it for me
  12. Oct 30, 2012 at 7:10 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    see the pdf above ^
    then read up on the repair manual and write ups, then see if you want to take it on...it'll save you hundreds if you can do it yourself but your truck WILL be out of commission at least a full day if not two
  13. Oct 30, 2012 at 5:58 PM
    pinchetaco
    Winston Salem, NC
    I went ahead and decided to clean the engine of the oil again just to be sure as you recommended. Just to make sure that's where the leak is coming from. So ill give it a couple of days and see what the results are.
  14. Oct 30, 2012 at 6:17 PM
    matadorCE
    matadorCE Well-Known Member
    Is this only an issue for the 05-08 as the TSB says or is it just because the that's the year that the TSB was put out?
  15. Oct 30, 2012 at 7:04 PM
    badger
    badger Well-Known Member
    07 SR5
    My 07 is weeping oil. As long as I can pour it in faster than it's coming out, I'm not touching it.
  16. Oct 30, 2012 at 7:24 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    yes, my understanding is toyota noticed this issue and changed their production methods and added more fip to the seal to prevent the leak in the more recent years
  17. Oct 30, 2012 at 11:52 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Where is it weeping from? I need to check my truck for this. Don't know when or if my 5 year warranty is up yet. Should be close.
  18. Oct 31, 2012 at 6:55 AM
    BamaToy1997
    Bill
    Navarre, FL
    Check the TSB link posted above. It has an image that shows where these are leaking from, IF it is related to the TSB.
  19. Oct 31, 2012 at 10:08 AM
    badger
    07 SR5
    Damn it Bama,...I takes me 20 minutes to read one sentence of your posts :p
  20. Oct 31, 2012 at 10:53 AM
    matadorCE
    I'm looking into buying a 2nd gen (looking at a '05 tomorrow) but this issue has me worried. It just sucks to have to do a 8+hr repair just because they didn't use enough FIPG. I'm just afraid that I'll go check out this truck (or any other in the future) and either it'll have this issue or if not I'll be wondering when it'll get it in the future.
