Leaky gasket on coolant bypass housing.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joramgiles, Feb 22, 2016.
  1. Feb 22, 2016 at 12:01 PM
    joramgiles
    joramgiles [OP] New Member
    Joram
    2005 Extended Cab Tacoma 2.7 L
    2005 2.7 L Tacoma. I have a coolant leak on what I believe is the coolant bypass housing - sort of behind the thermostat housing. It's very tight in there. I successfully removed the housing but I imagine I'll have to remove the intake manifold in order to actually fix it. Anyone have experience doing this?
    TnShooter likes this.
  2. Feb 22, 2016 at 2:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The service manual says the intake has to come off, but some have said they replaced it without removing the intake. It is very tight in there.
    Is this it:
    If it were mine I would get the replacement pipe that is all metal and not plastic. Your leak is probably the joint in the pipe and not the gasket. That was the reason in the redesign to an all metal pipe assembly.
    The new part number is: 16268-75110 and gasket # 16258-75021.
    Dan 77, Oldsalero13, REDdawn6 and 3 others like this.
  3. Feb 22, 2016 at 4:12 PM
    joramgiles
    Joram
    thank you Jimmyh!
  4. Feb 23, 2016 at 2:20 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  5. Dec 19, 2017 at 10:31 AM
    Crawfishpot
    Crawfishpot New Member
    First post. Hi everyone. 1996 Taco 2.4 2wd
    I know this is about a 2.7 3rz, but in a search for the gasket for my 96 2.4 2rz I found that there is a different gasket then the 3rz. The gasket for the 2rz is #16268G which is in the last picture.
    taco97headache likes this.
  6. Dec 19, 2017 at 8:40 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well this was actually about the 2.7 liter 2TR-FE engine.
  7. Dec 19, 2017 at 8:42 PM
    Crawfishpot
    What year did they change from the 3rz?
  8. Dec 19, 2017 at 8:52 PM
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    I have a 2005 2.7 and I have this exact leak I think coming from the coolant bypass housing. Is the power steering resovior right above the bypass housing? Just trying to make sure this is what I'm looking at.
  9. Dec 20, 2017 at 9:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    In 2005 they changed from the 2.7 liter 3RZ-FE 150 HP to the 2.7 liter 2TR-FE 159 HP.
  10. Aug 30, 2019 at 12:58 AM
    Camcamyota
    Camcamyota New Member
    Cameron
    2005 Tacoma base
    Just bought it
    Just did this job on my 05 Tacoma, after the fight to get the damn thing in and all button up no I have over heating issue. Any suggestions?
  11. Aug 30, 2019 at 1:09 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Huh? I no understand the question. Restate or maybe some punctuation might help me.
  12. Aug 30, 2019 at 1:19 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    https://parts.olathetoyota.com/blog/9231/why-your-toyota-is-overheating
    1.) Make sure you have ALL of the air out of the system. Park nose up on a steep hill and run the engine until the thermostat opens and then add fluid as it is running until no more air comes out.
    2.) You could have a thermostat that is sticking closed. Did you remove the thermostat when doing the bypass pipe? Is the thermostat properly aligned in the housing. The hole or jiggle pin should be at the top of the housing + or - 10 degrees rotation.
    2TR-FE Engine
    Before servicing the vehicle, refer to the Precautions section.
    1. Drain engine coolant.
    2. Remove water inlet.
    3. Remove the bolt and 2 nuts, then remove the water inlet.
    4. Remove the gasket from the timing chain cover.
    5. Remove the thermostat from the timing chain cover.
    To install:
    1. Install a new gasket onto the thermostat.
    2. Install the thermostat with the jiggle valve upward.
      NOTE
      The jiggle valve may be set within 10° to either side of vertical position.
    3. Install a new gasket and the water inlet with the bolt and 2 nuts. Tighten to 20 Nm (15 ft. lbs.).
    4. Add engine coolant.
    5. Check for engine coolant leakage.
    3.) Make sure the clutch fan is working properly. https://www.wikihow.com/Test-a-Fan-Clutch
  13. Mar 12, 2020 at 10:40 AM
    Sparshooter
    Sparshooter Member
    2005 Tacoma SR5 4x4
  14. Mar 12, 2020 at 10:44 AM
    Sparshooter
    Sparshooter Member
    2005 Tacoma SR5 4x4
    Jimmyh, I ran those part numbers for the pipe & gasket past a guy I’ve been dealing with at a parts store, and he said his system showed these part numbers won’t fit on the ‘05 Tacoma 2.7L. Only for 2012 to 2019. Is his information incorrect? I’ve had it happen at a part store in the past with a 69 Mustang. Was the part re-engineered in 2012? Which would explain why it shows from that year forward?
  15. Mar 12, 2020 at 2:35 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    See below.
  16. Mar 13, 2020 at 1:36 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I would check with Toyota about the engine you have. The information I posted about the parts for the second generation Tacoma 2.7 liter 2TR-FE Engine.
    This is what I see now.
    GASKET(FOR WATER BY-PASS PIPE)
    Part Number: 1625875010
    Supersession(s): 16258-75010
    Fits 4Runner, Tacoma
    Toyota 4Runner 2.7L 2WD AT SR5 2010
    Toyota Tacoma 2.7L 4x2 AT Double Cab 2011, 2012
    Toyota Tacoma 2.7L 4x2 AT LARGE CAB 2008, 2009, 2010, 2011, 2012
    Toyota Tacoma 2.7L 4x2 AT Regular Cab 2008, 2009, 2010, 2011, 2012
    Toyota Tacoma 2.7L 4x2 MT LARGE CAB 2008, 2009, 2010, 2011, 2012
    Toyota Tacoma 2.7L 4x2 MT Regular Cab 2008, 2009, 2010, 2011, 2012
    Toyota Tacoma 2.7L 4x4 AT LARGE CAB 2011, 2012
    Toyota Tacoma 2.7L 4x4 AT Regular Cab 2011, 2012
    Toyota Tacoma 2.7L 4x4 MT LARGE CAB 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
    Toyota Tacoma 2.7L 4x4 MT Regular Cab 2005, 2006, 2007, 2008, 2009, 2010, 2011
    Toyota Tacoma 2.7L AT LARGE CAB 2005, 2006, 2007
    Toyota Tacoma 2.7L AT Regular Cab 2005, 2006, 2007
    Toyota Tacoma 2.7L MT LARGE CAB 2005, 2006, 2007
    Toyota Tacoma 2.7L MT Regular Cab 2005, 2006, 2007
  17. Apr 20, 2020 at 6:04 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    So I just did this and replaced it with the metal pipe and my problem seems worse. With the metal pipe, there is no spot for a gasket, so I put it on and torqued it down.
    On the plastic pipe, the gasket slot is in the pipe.
    Am I missing something?
  18. Apr 20, 2020 at 6:07 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Incorrect assembly or incorrect gasket.
    The new gasket/seal for the metal pipe should look like this:
  19. Apr 20, 2020 at 6:09 PM
    Levalexi
    Southern Maine
    There was no gasket. Not even a spot on the pipe or seating surface on the block for one.
    It's flush, I cleaned both surfaces off before installation and properly torqued it.
  20. Apr 20, 2020 at 6:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    This is what you should have:
