Leaky gasket on coolant bypass housing.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joramgiles, Feb 22, 2016.
  1. Apr 20, 2020 at 6:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is why it is leaking you didn't install a gasket or seal at all.
    See my corrected post above. I had it backwards between the two gaskets and pipes.
    There should be a flat gasket on the flange. See part numbers above.
    I hope this helps. It sucks that you will have to do it over.
  2. Apr 21, 2020 at 7:44 AM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    I picked up the correct gasket today. And I was able to install it without removing anything but the bolts.
    I accessed the forward bolts from the top, and the rear one from under the truck. Move the pipe aft and slide the gasket in
  3. Apr 21, 2020 at 9:52 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
    I pray you have no more leaks?
    Did you buy the pipe from Toyota? I'm surprised that they didn't tell you that you would need a gasket to go with the replacement steel pipe.
  4. Apr 21, 2020 at 10:37 AM
    Levalexi
    Southern Maine
    It's looking like that so far. The pipe is bone Dry right now. Gonna go wash the truck and park in a different spot.
    I didn't see any new drips, or steady streams, just from what was left over from when I drained it
    Jimmyh[QUOTED] likes this.
  5. Nov 8, 2024 at 3:19 PM
    Flingel Bunt
    Flingel Bunt Member
    I had to replace this part on my 2010 Tacoma 5 years ago. Here's what I had to disconnect/remove to get to it:
    Air intake assembly
    Throttle body
    Fuel injection lines
    Intake manifold
    Driver side front wheel (to get to bottom bolts on manifold)
    Various vacuum lines and wiring harnesses
    For me this was a day and a half of work. The part alone was about $70. My Toyota dealer offered to do the job for around a grand, understandable considering the labor involved.
    What ticked me off about this is that the original bypass tube was made out of plastic and was disintegrating like old rotten particle board when I replaced it with the stainless-steel upgrade. I can imagine some weenie at Toyota patting himself on the back for all the money he saved using crap-tier materials.
    Same thing with my radiator last week. Investigating a leak, I pulled the upper coolant hose from the radiator and the plastic connection nipple of the radiator broke into pieces.
  6. Nov 8, 2024 at 3:28 PM
    Flingel Bunt
    Flingel Bunt Member
